Trying to reference in an array
I have built a unit, which tunes to 6 radio stations on site, and sends a sms message, when one or all of them fail.
the message contains the frequency, from a look up list.
I have had substantial help with the programming. BTW.
The BUGS, I’m trying to fix.
I only want one message to be sent if the radio site is shutdown(i.e no stereo), at the moment it sends sms constantly.
I then want to be able to send an sms when the site is back on.
I feel I need to some how reference to the different positions in the frequency array.
any thoughts.
#include <GSM.h>
#include <LiquidCrystal.h>
// //#include <Si4703_Breakout.h>
#include <Wire.h>
#include <TEA5767.h>
// from https://github.com/andykarpov/TEA5767
#include <Button.h>
// from http://arduino-info.wikispaces.com/HAL-LibrariesUpdates
// PIN Number
#define PINNUMBER ""
GSM gsmAccess;     //
GSM_SMS sms;
GSMVoiceCall vcs;
// Array to hold the number for the incoming call
char numtel[20];
////////////////////////////// TEA5767 /////////////////////
TEA5767 Radio;
double old_frequency;
double frequency;
int search_mode = 0;
int search_direction;
unsigned long last_pressed;
///////////////////////////// LCD //////////////////////////
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 9, 8);
// This section descibes button connection.
const int buttonPin = A0;
const int upbuttPin = A2;
const int downbuttPin = A3;
const int selectPin =  A1;
const int smsmutePin = 6;
const int led1Pin = A4;
const int led2Pin = A5;
const int sensorPin = A15;
const int DABsoloPin = 53;
const int DABenablePin = 51;
unsigned long LastStationSwitch = 0;
int currentStation = -1;
unsigned long lastNoise;
///////////freq map//////////////////////
float Freq[][5] ={
    98.2, 88.6 , 90.8, 93.0, 100.4                                                        }
  ,//Atest
    99.5, 89.9 , 91.4, 104.7, 93.6                                                        }
  ,//Aberdare
    98.3 , 88.7, 90.9, 93.1, 103.5                                                        }
  ,//Abergavenny
    98.6 , 89.0, 91.2, 93.4, 104.3                                                     }
  ,//Abertillery
    98.1 , 88.5, 90.7, 92.9, 104.0                                                     }
  ,//Blaenavon
    98.5 , 88.9, 91.1, 104.7, 93.3                                                      }
  ,//Brecon
    98.0 , 88.4, 90.6, 104.6, 92.8                                                      }
  ,//Carmel
    89.5 , 91.7, 93.9, 96.4, 0                                                      }
  ,//kvh
    99.5 , 89.9, 92.1, 94.3, 101.7                                                     }
  ,//Wenvoe
  ,//kvh
  ,//kvh
  ,//kvh
  ,//kvh
const int NUM_FREQS = sizeof Freq[0]/sizeof Freq[0][0];
boolean channelState[NUM_FREQS];
// variables will change:
int buttonState = 0;
int upbuttState = 0;
int downbuttState = 0;
int selectbuttState = 0;
int smsmuteState = 0;
int select = 0;
float channel;
int countAV = 0;
int countSENT = 0;
// ---- DAB ---
int AVlevel = 0;
int DABsolo = 0;
int DABenable = 0;
//int DABsoloPin = 0;
//int DABenablePin = 0;
// Save data variables
String IMEI = "";
// serial monitor result messages
String errortext = "ERROR";
///////////////////////// NAME INDEX ////////////////////////////////
char * Names[] = {
  "A-RHA", "Aberdare  ", "Abergavenny  ", "Abertillery", "Blaenavon", "Brecon", "Carmel", "Kilvey Hill", "Wenvoe" };
const int NAME_COUNT = sizeof Names / sizeof Names[0];
int NameIndex = 0;
// ____________________________________________________________________________________________
  Wire.begin();
  Radio.init();
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(upbuttPin, INPUT);
  pinMode(downbuttPin, INPUT);
  pinMode(selectPin, INPUT);
  pinMode(smsmutePin, INPUT);
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(DABsoloPin, INPUT);
  digitalWrite(DABsoloPin, HIGH);
  pinMode(DABenablePin, INPUT);
  digitalWrite(DABenablePin, HIGH);
  ///pinMode(LEDAVPin, OUTPUT);
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Receive Voice Call");
  /////////////////////// LCD BOOT  turn on display? ////////////////////
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("FM Rover by DM");
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("--Please  Wait--");
  lcd.setCursor(0, 1);
  lcd.print("-GSM Connecting-");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      digitalWrite(A5, HIGH);
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print(" GSM  Connected");
      lcd.clear();
      Serial.println("Not connected !");
      digitalWrite(A5, LOW);
      lcd.clear();
      lcd.print("NO GSM !");
  vcs.hangCall();
  Serial.println("Waiting for a call");
  ///////////////// SELECT SITE NAME //////////////////////
  while(select==0){
    // read the state of the pushbutton value:
    upbuttState = digitalRead(upbuttPin);
    downbuttState = digitalRead(downbuttPin);
    selectbuttState = digitalRead(selectPin);
    // if it is, the upbuttState is HIGH:
    if (upbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex+1)%NAME_COUNT;
    } // Wrap around
    //if it is, the upbuttState is HIGH:
    if (downbuttState == HIGH) {
      // increment name
      NameIndex = (NameIndex-1)%NAME_COUNT;
      if (NameIndex < 0) {
        NameIndex=NAME_COUNT-1;
    } // Wrap around
    if (selectbuttState == HIGH){
      select=1;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("> ");
    lcd.setCursor(2,0);
    lcd.print (Names[NameIndex]);
    lcd.setCursor(0,1);
    lcd.print("Select Location ");
    delay(250);
    lcd.clear();
  lcd.clear();
  for (int i =0; i < NUM_FREQS; i++)
    channelState[i] = true;
// ____________________  VOICE CALL _____________________________
  // Check the status of the voice call
  switch (vcs.getvoiceCallStatus())
  case IDLE_CALL: // Nothing is happening
    lcd.setCursor(6,1);
    lcd.print("    ");
  case RECEIVINGCALL: // Yes! Someone is calling us
    lcd.setCursor(6,1);
    lcd.print("RING");
    Serial.println("RECEIVING CALL");
    //  lcd.clear();
    // lcd.setCursor(0,0);
    //lcd.print("RECEIVING CALL");
    // Retrieve the calling number
    vcs.retrieveCallingNumber(numtel, 20);
    // Print the calling number
    Serial.print("Number:");
    Serial.println(numtel);
    //  lcd.setCursor(0,1);
    //  lcd.print(numtel);
    // Answer the call, establish the call
    vcs.answerCall();
    currentStation=-1;
  case TALKING:  // In this case the call would be established
    //lcd.clear();
    lcd.setCursor(6,1);
    lcd.print("CALL");
    Serial.println("TALKING. Press enter to hang up.");
    if(Serial.read()!='\n')
      delay(100);
    //vcs.hangCall();
    Serial.println("Hanging up and waiting for the next call.");
second half of code
// __________________ TUNE RADIO ________________________________
  DABsolo = digitalRead(DABsoloPin);
  if(DABsolo == HIGH){
    unsigned char buf[5];
    unsigned long current_millis = millis();
    //if(DABsolo == HIGH)
    if (current_millis>LastStationSwitch+(TALKING ==vcs.getvoiceCallStatus()?10000:3000))
      // for(int i=0; i<NUM_FREQS; i++)
      if (currentStation != -1 && Radio.read_status(buf) == 1)
        int stereo = Radio.stereo(buf);
        // lcd.print(i+1);
        //delay(1000);
        if (stereo)
          channelState[currentStation] = true;
          digitalWrite(A4, LOW);
          // lcd.print(" MO");
          lcd.clear();
          lcd.setCursor(0,1);
          lcd.print("--- FM FAULT ---");
          lcd.clear();
          if (smsmuteState == HIGH)
            lcd.setCursor(0,0);
            lcd.print("GSM  SEND  MUTED");
            lcd.clear();
          if (smsmuteState == LOW && channelState[currentStation])
            channelState[currentStation] = false;
            lcd.clear();
            sms.beginSMS("07766404142");
            lcd.print("SMS SENDING >>>>");
            sms.print("arduinodm\xFEgmail.com ");
            sms.print(Names[NameIndex]);
            sms.print("  ");
            sms.print(channel);
            sms.print(" SHUT DOWN");
            sms.endSMS();
            lcd.clear();
            lcd.print("SMS SENT OK");
            lcd.clear();
      currentStation++;
      if(currentStation>=NUM_FREQS)
        currentStation =0;
      LastStationSwitch=current_millis;
      channel=Freq[NameIndex][currentStation];
      Radio.set_frequency(channel);
      //delay(200);// allow time to tune
      smsmuteState = digitalRead(smsmutePin);
      // lcd.clear();
      // lcd.setCursor(0, 1);
      //  lcd.print(Names[NameIndex]);
      // if(TALKING ==vcs.getvoiceCallStatus())
      // delay(20000);
  if (Radio.read_status(buf) == 1)
    float current_freq =  floor (Radio.frequency_available (buf) / 100000 + .5) / 10;
    int signal_level = Radio.signal_level(buf);
    lcd.setCursor(0,0);
    lcd.print(current_freq);
    lcd.setCursor(6,0);
    lcd.print("MHz");
    lcd.setCursor(10,0);
    lcd.print(signal_level *  100 / 15);
    lcd.setCursor(13,0);
    lcd.print("%");
    lcd.setCursor(15, 1);
    if (stereo)
      lcd.setCursor(14, 0);
      lcd.print("ST ");
      digitalWrite(A4, HIGH);
      lcd.print("MO ");
  DABenable = digitalRead(DABenablePin);
  //lcd.clear();
  if(DABenable==LOW)
    if(DABsolo==LOW)
      lcd.setCursor(0,0);
      lcd.print("    DAB solo   ");
    AVlevel = analogRead(sensorPin);
    //lcd.clear();
    lcd.setCursor(12,1);
    if(AVlevel<1000)
      lcd.print(" ");
    if(AVlevel<100)
      lcd.print(" ");
    if(AVlevel<10)
      lcd.print(" ");
    lcd.print(AVlevel, 1024);
    lcd.setCursor(10,1);
    lcd.print("  A");
    lcd.setCursor(0,1);
    if(countAV<1000)
      lcd.print(" ");
    if(countAV<100)
      lcd.print(" ");
    if(countAV<10)
      lcd.print(" ");
    lcd.print(countAV);
    if(AVlevel<70 && countAV<1200)
      //digitalWrite(LEDAVPin, HIGH);
      delay(100);
      countAV++;
        if(AVlevel<70 &&countAV>119 && countSENT<1)
        // digitalWrite(LEDAVPin, HIGH);
        lcd.clear();
        lcd.print("DAB FAULT >>>>");
        // sms.print("  ");
        // sms.print(channel);
        sms.print(" DAB DEMOD FAIL !");
        sms.endSMS();
        lcd.clear();
        delay(2000);
        lcd.clear();
        countSENT++;
    //        else
    //          if(AVlevel<70 &&countAV>10 && countSENT>1)
    //            //  digitalWrite(LEDAVPin, LOW);
    //            delay(1000);
          if(AVlevel>72) // && count==0)
          countAV=0;
          countSENT=0;
    delay(100);
You can attach code in once piece.
How to use this forum
Try again
Final2WorkingDVBsend.ino (17.7 KB)
I think that this is poor programming style. Use some spaces. Separate this into multiple statements. Ditch the ternary operator.
That code seriously needs commenting. You may be intimately familiar with the Radio and vcs classes, but no one else is. You may understand what channelState means, but you are the only one that does. If the name was something like channelActive, one could make a reasonable guess what a value of true means. But, not with a name like channelState. I'd expect channelState to contain values like DEAD, TRANSMITTING, RECEIVING, etc.
The case of your variable names is horrid. PascalCase or camelCase are the normal formats. weirdformatWhereTheFirstTwoWordsAreLowerCase is not.
What have you tried to keep the code from sending the message more than once?
