Trying to Reset Arduino NANO 33 IoT programatically
Hi, I have tried some different approaches seen online and in Arduino Forums with no success..
I have tried the
int led = 13;
void(* resetFunc) (void) = 0; //declare reset function @ address 0
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  Serial.begin(115200);//initialize the serial port
// the loop routine runs over and over again forever:
  //digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  Serial.println("on");
  delay(10000);               // wait for 10 seconds
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  Serial.println("off");
  delay(5000);               // wait for  5 seconds
  Serial.println("resetting again");
  resetFunc();  //call reset
  delay(100);
  Serial.println("never happens");
I was expecting the Arduino to reset time after time .. It just stops.
The same with this other approach
int led = 13;
#define HMCRAMC0_SIZE     0x8000UL
#define HMCRAMC0_ADDR    (0x20000000U)
#define MAGIC_VALUE         0x07738135U
void ResetToBoot()
    Serial.println("rebooting Now");
    *((volatile uint32_t *)(HMCRAMC0_ADDR + HMCRAMC0_SIZE - 4)) = MAGIC_VALUE;
    NVIC_SystemReset();
    Serial.println("rebooted Not");
  ResetToBoot();  //call reset
  delay(100);
as planned the Serial.println("rebooted Not") in Reset To Boot function is never triggered
and neither is the Serial.println("never happens").
The Arduino just stops working until it is restarted manually..
Has anybody any working solution to this or any insights in how to get the Arduino NANO to perform a proper reboot from Code.
Hi pelago,
To reset the Nano 33 IoT and restart your sketch, you just need to use the line:
NVIC_SystemReset();                         // Reset the microcontroller
By the way, the code in your second example resets the board, but places the microcontroller into bootloader mode, (simulating a double tap reset).
Thank you MartinL for the clarification. Now i get it to work properly.
:slight_smile:
