Trying to run MLX90640 on Teensy 4.0, code will not compile
Hello, I am very new to the whole arduino/programming scene and I am trying to make a simple thermal camera using the adafruit MLX90640 with the Teensy 4.0. Im pretty sure I have everything wired correctly, I was able to run a test that gave me ASCII readings for the sensor. But when I try to compile the code I keep getting this error " 'Adafruit_Arcada' does not name a type ". I got the code from here -Adafruit_MLX90640/MLX90640_arcadaCam.ino at master · adafruit/Adafruit_MLX90640 · GitHub
Please help !
You probably forget to install the Adafruit_Arcade library. Do you use the corresponding hardware?
I have all the libraries downloaded from adafruit
All? Really?
Post the complete output you get from the IDE!
Arduino: 1.8.19 (Windows 10), TD: 1.56, Board: "Teensy 4.1, Serial, 600 MHz, Faster, US English"
C:\Users\migz1\OneDrive\Documents\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\migz1\OneDrive\Documents\Arduino\hardware -hardware C:\Users\migz1\AppData\Local\Arduino15\packages -tools C:\Users\migz1\OneDrive\Documents\Arduino\tools-builder -tools C:\Users\migz1\OneDrive\Documents\Arduino\hardware\tools\avr -tools C:\Users\migz1\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\migz1\OneDrive\Documents\Arduino\libraries -libraries C:\Users\migz1\OneDrive\Documents\Arduino\libraries\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path C:\Users\migz1\AppData\Local\Temp\arduino_build_639748 -warnings=none -build-cache C:\Users\migz1\AppData\Local\Temp\arduino_cache_838162 -verbose C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\examples\MLX90640_arcadaCam\MLX90640_arcadaCam.ino
C:\Users\migz1\OneDrive\Documents\Arduino\arduino-builder -compile -logger=machine -hardware C:\Users\migz1\OneDrive\Documents\Arduino\hardware -hardware C:\Users\migz1\AppData\Local\Arduino15\packages -tools C:\Users\migz1\OneDrive\Documents\Arduino\tools-builder -tools C:\Users\migz1\OneDrive\Documents\Arduino\hardware\tools\avr -tools C:\Users\migz1\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\migz1\OneDrive\Documents\Arduino\libraries -libraries C:\Users\migz1\OneDrive\Documents\Arduino\libraries\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path C:\Users\migz1\AppData\Local\Temp\arduino_build_639748 -warnings=none -build-cache C:\Users\migz1\AppData\Local\Temp\arduino_cache_838162 -verbose C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\examples\MLX90640_arcadaCam\MLX90640_arcadaCam.ino
Using board 'teensy41' from platform in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Adafruit_MLX90640.h: [Adafruit_MLX90640@1.0.2]
ResolveLibrary(Adafruit_MLX90640.h)
-> candidates: [Adafruit_MLX90640@1.0.2]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.10.1]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.10.1]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Adafruit_Arcada.h: [Adafruit_Arcada_Library@2.5.2]
ResolveLibrary(Adafruit_Arcada.h)
-> candidates: [Adafruit_Arcada_Library@2.5.2]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.12]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.10.12]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for Adafruit_NeoPixel.h: [Adafruit_NeoPixel@1.10.3 Adafruit_NeoPixel@1.1.7]
ResolveLibrary(Adafruit_NeoPixel.h)
-> candidates: [Adafruit_NeoPixel@1.10.3 Adafruit_NeoPixel@1.1.7]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
Alternatives for TouchScreen.h: [Adafruit_TouchScreen@1.1.3 TouchScreen]
ResolveLibrary(TouchScreen.h)
-> candidates: [Adafruit_TouchScreen@1.1.3 TouchScreen]
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\Adafruit_MLX90640.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility\MLX90640_API.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility\MLX90640_I2C_Driver.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640\utility\MLX90640_SWI2C_Driver.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\WireIMXRT.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_Alerts.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_Config.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_Filesystem.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_ImageReader.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_InternalFlash.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_USBMSD.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_Wav.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel\esp8266.c" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp" -o nul
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen\TouchScreen.cpp" -o nul
Generating function prototypes...
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\migz1\OneDrive\Documents\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748" "C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748/pch/Arduino.h" -o "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748/pch/Arduino.h.gch"
"C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\migz1\AppData\Local\Temp\arduino_build_639748/pch" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen" "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp" -o "C:\Users\migz1\AppData\Local\Temp\arduino_build_639748\sketch\MLX90640_arcadaCam.ino.cpp.o"
MLX90640_arcadaCam:3: error: 'Adafruit_Arcada' does not name a type
Adafruit_Arcada arcada;
MLX90640_arcadaCam: In function 'void setup()':
MLX90640_arcadaCam:47: error: 'arcada' was not declared in this scope
if (!arcada.arcadaBegin()) {
MLX90640_arcadaCam:51: error: 'arcada' was not declared in this scope
arcada.displayBegin();
MLX90640_arcadaCam: In function 'void loop()':
MLX90640_arcadaCam:102: error: 'arcada' was not declared in this scope
   arcada.display->fillRect(displayPixelWidth * w, displayPixelHeight * h,
MLX90640_arcadaCam:89: warning: unused variable 'colorTemp'
int colorTemp;
Multiple libraries were found for "Adafruit_NeoPixel.h"
Used: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel
Not used: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_NeoPixel
Multiple libraries were found for "TouchScreen.h"
Used: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen
Not used: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_TouchScreen
Using library Adafruit_MLX90640 at version 1.0.2 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_MLX90640
Using library Adafruit_BusIO at version 1.10.1 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Wire
Using library Adafruit_Arcada_Library at version 2.5.2 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_Arcada_Library
Using library Adafruit_GFX_Library at version 1.10.12 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_NeoPixel at version 1.1.7 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\Adafruit_NeoPixel
Using library SPI at version 1.0 in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\SPI
Using library TouchScreen in folder: C:\Users\migz1\OneDrive\Documents\Arduino\hardware\teensy\avr\libraries\TouchScreen (legacy)
What do you mean by this?
Please post error messages in code tags.
Maybe the board you selected is incorrect? I believe you wanted to use teensy 4.0?
I selected the teensy 4.0 and it still does not compile
I have been able to run the simple test included in the library and it works fine but when I try the real program it does not, It seems there is a mistake in the code idk?
