Trying to scan 2 or 1 card to allow access and any other card denies access
Is there anyway to make the code less complicated?
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Please present card to the reader...");
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "1A 80 FD DA"||"DB 93 46 E0")
    Serial.println("Please scan other card for access");
    delay(3000);
      Serial.println("Try again");
      return;
      return;
      String content= "";
      byte letter;
      if (content.substring(1) == "DB 93 46 E0")
        Serial.println("Access granted");
        delay(3000);
        Serial.println(" Access denied");
        delay(3000);
    delay(3000);
Welcome
Yes, don't use String :slight_smile:
The card id is a 4-bytes number, so if you combine those bytes, then you can easily compare the card id to a number
And this is wrong
You can't do multiple comparisons like that
C++ isn't that close to English. You have to write this as something like:
Thanks for the welcome
I am new to coding and do not know much.
Do you have a suggestion for not using string?
Could you provide an example code?
Post your new, changed, code. Without it, we can't help you more.
Whoops sorry for the confusion, I simply forgot to compile and upload my new code.
Everything is working as it seems now. Thanks
