Trying to send a image over nrf24 using arduiono uno
I have 2 arduiono's uno's one with a camera that sends photos to the second arduiono, currently the photo comes across currupted half the size it should be, the jpeg markers show up ill post the client code and I can provide the server if needed, the important function is read_fifo_burst
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <RH_NRF24.h>
#include <SD.h>
// set up variables using the SD utility library functions:
File myFile;
// Singleton instance of the radio driver
RH_NRF24 nrf24;
// #include "memorysaver.h"
#define BMPIMAGEOFFSET 66
const char bmp_header[BMPIMAGEOFFSET] PROGMEM =
  0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
  0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
  0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
  0x00, 0x00
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
bool is_header = false;
int mode = 0;
uint8_t start_capture = 0;
 ArduCAM myCAM( OV5642, CS );
uint8_t read_fifo_burst(ArduCAM myCAM);
int sensor = 2;              // the pin that the sensor is atteched to
int state = LOW;             // by default, no motion detected
int val = 0;                 // variable to store the sensor status (value)
//sd card setup comes from code example check that for the logic
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  while (!Serial)
    ; // wait for serial port to connect. Needed for Leonardo only
  if (!nrf24.init())
    Serial.println("init failed");
  // Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
  if (!nrf24.setChannel(1))
    Serial.println("setChannel failed");
  if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
    Serial.println("setRF failed");
pinMode(sensor, INPUT);    // initialize sensor as an input
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
  Wire1.begin();
#else
  Wire.begin();
  Serial.begin(921600);
#endif
Serial.println(F("ACK CMD ArduCAM Start! END"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
 //Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if (temp != 0x55){
    Serial.println(F("ACK CMD SPI interface Error! END"));
    delay(1000);continue;
  }else{
    Serial.println(F("ACK CMD SPI interface OK. END"));break;
  while(1){
    //Check if the camera module type is OV5642
    myCAM.wrSensorReg16_8(0xff, 0x01);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
    if((vid != 0x56) || (pid != 0x42)){
      Serial.println(F("ACK CMD Can't find OV5642 module! END"));
    else{
      Serial.println(F("ACK CMD OV5642 detected. END"));break;
//Change to JPEG capture mode and initialize the OV5642 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES,0x00);
// motion code to trigger photo
uint8_t temp = 0xff, temp_last = 0;
val = digitalRead(sensor);   // read sensor value
  if (val == HIGH) {           // check if the sensor is HIGH
    if (state == LOW) {
      Serial.println(F("Motion detected!"));
      state = HIGH;       // update variable state to HIGH
      // take picture by setting temp value for switch case below
      temp = 0x10;
  else {
      //digitalWrite(led, LOW); // turn LED OFF
      delay(200);             // delay 200 milliseconds
      if (state == HIGH){
        Serial.println(F("Motion stopped!"));
        state = LOW;       // update variable state to LOW
if (Serial.available())
  switch (temp)
    case 0:
      myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_320x240 END"));
    temp = 0xff;
    case 1:
      myCAM.OV5642_set_JPEG_size(OV5642_640x480);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_640x480 END"));
    temp = 0xff;
    case 2:
      myCAM.OV5642_set_JPEG_size(OV5642_1024x768);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_1024x768 END"));
    temp = 0xff;
    case 3:
    temp = 0xff;
      myCAM.OV5642_set_JPEG_size(OV5642_1280x960);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_1280x960 END"));
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    Serial.println(F("ACK CMD CAM start single shoot. END"));
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    #if !(defined (OV2640_MINI_2MP))
    myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
    #endif
    case 0x40:
    myCAM.OV5642_set_Light_Mode(Advanced_AWB);temp = 0xff;
     Serial.println(F("ACK CMD Set to Advanced_AWB END"));break;
    case 0x41:
    myCAM.OV5642_set_Light_Mode(Simple_AWB);temp = 0xff;
     Serial.println(F("ACK CMD Set to Simple_AWB END"));break;
     case 0x42:
    myCAM.OV5642_set_Light_Mode(Manual_day);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_day END"));break;
     case 0x43:
    myCAM.OV5642_set_Light_Mode(Manual_A);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_A END"));break;
     case 0x44:
    myCAM.OV5642_set_Light_Mode(Manual_cwf);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_cwf END"));break;
     case 0x45:
    myCAM.OV5642_set_Light_Mode(Manual_cloudy);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_cloudy END"));break;
      case 0x50:
    myCAM.OV5642_set_Color_Saturation(Saturation4);temp = 0xff;
     Serial.println(F("ACK CMD Set to Saturation+4 END"));break;
   case 0x51:
      myCAM.OV5642_set_Color_Saturation(Saturation3);temp = 0xff;
     Serial.println(F("ACK CMD Set to Saturation+3 END"));break;
   case 0x52:
    myCAM.OV5642_set_Color_Saturation(Saturation2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+2 END"));break;
  case 0x53:
    myCAM.OV5642_set_Color_Saturation(Saturation1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+1 END"));break;
   case 0x54:
    myCAM.OV5642_set_Color_Saturation(Saturation0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+0 END"));break;
   case 0x55:
    myCAM.OV5642_set_Color_Saturation(Saturation_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-1 END"));break;
   case 0x56:
    myCAM.OV5642_set_Color_Saturation(Saturation_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-2"));break;
    case 0x57:
    myCAM.OV5642_set_Color_Saturation(Saturation_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-3 END"));break;
   case 0x58:
  myCAM.OV5642_set_Light_Mode(Saturation_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-4 END"));break;
   case 0x60:
  myCAM.OV5642_set_Brightness(Brightness4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+4 END"));break;
  case 0x61:
  myCAM.OV5642_set_Brightness(Brightness3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+3 END"));break;
  case 0x62:
  myCAM.OV5642_set_Brightness(Brightness2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+2 END"));break;
   case 0x63:
  myCAM.OV5642_set_Brightness(Brightness1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+1 END"));break;
   case 0x64:
  myCAM.OV5642_set_Brightness(Brightness0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+0 END"));break;
    case 0x65:
  myCAM.OV5642_set_Brightness(Brightness_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-1 END"));break;
     case 0x66:
  myCAM.OV5642_set_Brightness(Brightness_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-2 END"));break;
    case 0x67:
  myCAM.OV5642_set_Brightness(Brightness_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-3 END"));break;
    case 0x68:
  myCAM.OV5642_set_Brightness(Brightness_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-4 END"));break;
case 0x70:
  myCAM.OV5642_set_Contrast(Contrast4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+4 END"));break;
  case 0x71:
  myCAM.OV5642_set_Contrast(Contrast3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+3 END"));break;
  case 0x72:
  myCAM.OV5642_set_Contrast(Contrast2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+2 END"));break;
   case 0x73:
  myCAM.OV5642_set_Contrast(Contrast1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+1 END"));break;
   case 0x74:
  myCAM.OV5642_set_Contrast(Contrast0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+0 END"));break;
    case 0x75:
  myCAM.OV5642_set_Contrast(Contrast_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-1 END"));break;
     case 0x76:
  myCAM.OV5642_set_Contrast(Contrast_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-2 END"));break;
    case 0x77:
  myCAM.OV5642_set_Contrast(Contrast_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-3 END"));break;
    case 0x78:
  myCAM.OV5642_set_Contrast(Contrast_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-4 END"));break;
   case 0x80:
    myCAM.OV5642_set_hue(degree_180);temp = 0xff;
     Serial.println(F("ACK CMD Set to -180 degree END"));break;
   case 0x81:
   myCAM.OV5642_set_hue(degree_150);temp = 0xff;
     Serial.println(F("ACK CMD Set to -150 degree END"));break;
   case 0x82:
   myCAM.OV5642_set_hue(degree_120);temp = 0xff;
     Serial.println(F("ACK CMD Set to -120 degree END"));break;
   case 0x83:
   myCAM.OV5642_set_hue(degree_90);temp = 0xff;
     Serial.println(F("ACK CMD Set to -90 degree END"));break;
    case 0x84:
   myCAM.OV5642_set_hue(degree_60);temp = 0xff;
     Serial.println(F("ACK CMD Set to -60 degree END"));break;
    case 0x85:
   myCAM.OV5642_set_hue(degree_30);temp = 0xff;
     Serial.println(F("ACK CMD Set to -30 degree END"));break;
     case 0x86:
   myCAM.OV5642_set_hue(degree_0);temp = 0xff;
     Serial.println(F("ACK CMD Set to 0 degree END"));break;
   case 0x87:
   myCAM.OV5642_set_hue(degree30);temp = 0xff;
     Serial.println(F("ACK CMD Set to 30 degree END"));break;
   case 0x88:
   myCAM.OV5642_set_hue(degree60);temp = 0xff;
     Serial.println(F("ACK CMD Set to 60 degree END"));break;
    case 0x89:
   myCAM.OV5642_set_hue(degree90);temp = 0xff;
     Serial.println(F("ACK CMD Set to 90 degree END"));break;
     case 0x8a:
   myCAM.OV5642_set_hue(degree120);temp = 0xff;
     Serial.println(F("ACK CMD Set to 120 degree END"));break ;
   case 0x8b:
   myCAM.OV5642_set_hue(degree150);temp = 0xff;
     Serial.println(F("ACK CMD Set to 150 degree END"));break ;
   case 0x90:
   myCAM.OV5642_set_Special_effects(Normal);temp = 0xff;
     Serial.println(F("ACK CMD Set to Normal END"));break ;
      case 0x91:
   myCAM.OV5642_set_Special_effects(BW);temp = 0xff;
     Serial.println(F("ACK CMD Set to BW END"));break ;
    case 0x92:
   myCAM.OV5642_set_Special_effects(Bluish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Bluish END"));break ;
      case 0x93:
   myCAM.OV5642_set_Special_effects(Sepia);temp = 0xff;
     Serial.println(F("ACK CMD Set to Sepia END"));break ;
    case 0x94:
   myCAM.OV5642_set_Special_effects(Reddish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Reddish END"));break ;
   case 0x95:
   myCAM.OV5642_set_Special_effects(Greenish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Greenish END"));break ;
   case 0x96:
   myCAM.OV5642_set_Special_effects(Negative);temp = 0xff;
     Serial.println(F("ACK CMD Set to Negative END"));break ;
   case 0xA0:
   myCAM.OV5642_set_Exposure_level(Exposure_17_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.7EV"));break ;
     case 0xA1:
   myCAM.OV5642_set_Exposure_level(Exposure_13_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.3EV END"));break ;
      case 0xA2:
   myCAM.OV5642_set_Exposure_level(Exposure_10_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.0EV END"));break ;
    case 0xA3:
   myCAM.OV5642_set_Exposure_level(Exposure_07_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -0.7EV END"));break ;
     case 0xA4:
   myCAM.OV5642_set_Exposure_level(Exposure_03_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -0.3EV END"));break ;
   case 0xA5:
   myCAM.OV5642_set_Exposure_level(Exposure_default);temp = 0xff;
     Serial.println(F("ACK CMD Set to -Exposure_default END"));break ;
    case 0xA6:
   myCAM.OV5642_set_Exposure_level(Exposure07_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 0.7EV END"));break ;
   case 0xA7:
   myCAM.OV5642_set_Exposure_level(Exposure10_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.0EV END"));break ;
    case 0xA8:
   myCAM.OV5642_set_Exposure_level(Exposure13_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.3EV END"));break ;
    case 0xA9:
   myCAM.OV5642_set_Exposure_level(Exposure17_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.7EV END"));break ;
   case 0xB0:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness_default);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness default END"));break ;
    case 0xB1:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness1);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness +1 END"));break ;
    case 0xB2:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness2);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness +2 END"));break ;
      case 0xB3:
   myCAM.OV5642_set_Sharpness(Manual_Sharpnessoff);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness off END"));break ;
     case 0xB4:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness1);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +1 END"));break ;
     case 0xB5:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness2);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +2 END"));break ;
     case 0xB6:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness3);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +3 END"));break ;
     case 0xB7:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness4);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +4 END"));break ;
    case 0xB8:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness5);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +5 END"));break ;
    case 0xC0:
     myCAM.OV5642_set_Mirror_Flip(MIRROR);temp = 0xff;
     Serial.println(F("ACK CMD Set to MIRROR END"));break ;
    case 0xC1:
     myCAM.OV5642_set_Mirror_Flip(FLIP);temp = 0xff;
     Serial.println(F("ACK CMD Set to FLIP END"));break ;
    case 0xC2:
     myCAM.OV5642_set_Mirror_Flip(MIRROR_FLIP);temp = 0xff;
     Serial.println(F("ACK CMD Set to MIRROR&FLIP END"));break ;
    case 0xC3:
     myCAM.OV5642_set_Mirror_Flip(Normal);temp = 0xff;
     case 0xD0:
     myCAM.OV5642_set_Compress_quality(high_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to high quality END"));break ;
      case 0xD1:
     myCAM.OV5642_set_Compress_quality(default_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to default quality END"));break ;
      case 0xD2:
     myCAM.OV5642_set_Compress_quality(low_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to low quality END"));break ;
      case 0xE0:
     myCAM.OV5642_Test_Pattern(Color_bar);temp = 0xff;
     Serial.println(F("ACK CMD Set to Color bar END"));break ;
      case 0xE1:
     myCAM.OV5642_Test_Pattern(Color_square);temp = 0xff;
     Serial.println(F("ACK CMD Set to Color square END"));break ;
      case 0xE2:
     myCAM.OV5642_Test_Pattern(BW_square);temp = 0xff;
     Serial.println(F("ACK CMD Set to BW square END"));break ;
     case 0xE3:
     myCAM.OV5642_Test_Pattern(DLI);temp = 0xff;
     Serial.println(F("ACK CMD Set to DLI END"));break ;
      default:
if (mode == 1)
  if (start_capture == 1)
        Serial.println(F("INSIDE myCAM1"));
    myCAM.flush_fifo();
    //Start capture
    myCAM.start_capture();
    start_capture = 0;
  if (myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK))
    Serial.println(F("ACK CMD CAM Capture Done. END"));delay(50);
    read_fifo_burst(myCAM);
    //Clear the capture done flag
uint8_t read_fifo_burst(ArduCAM myCAM) {
    Serial.println(F("IN FIFO BURST"));
    uint8_t temp = 0, temp_last = 0;
    uint32_t length = 0;
    length = myCAM.read_fifo_length();
    Serial.println(length);
    Serial.println(length, DEC);
    if (length >= MAX_FIFO_SIZE) {  // 512 kb
        Serial.println(F("ACK CMD Over size. END"));
        return 0;
    if (length == 0) { // 0 kb
        Serial.println(F("ACK CMD Size is 0. END"));
        return 0;
    myCAM.CS_LOW();
    myCAM.set_fifo_burst(); // Set fifo burst mode
    temp = SPI.transfer(0x00);
    const int ARRAY_SIZE = 16; // Maximum testedNRF24L01+ payload size is 28
    uint8_t  buffer[ARRAY_SIZE];
    int buffer_index = 0;
    int count = 1;
    while (length--) {
        temp_last = temp;
        delay(100);
        if (is_header) {
            buffer[buffer_index++] = temp;
            if (buffer_index >= ARRAY_SIZE) {
                if (!send_with_retry(buffer, ARRAY_SIZE)) {
                    Serial.println(F("Failed after retries."));
                    myCAM.CS_HIGH();
                    return 0;
                // prints first 15 packets
              // Print details for the first 15 packets
                if (count < 15) {
                    Serial.print(F("Sending Packet number: "));
                    Serial.print(count);
                    Serial.print(F(", Buffer: "));
                    for (int i = 0; i < buffer_index; i++) {
                        Serial.print(buffer[i], HEX);
                        Serial.print(" ");
                buffer_index = 0;  // Reset buffer index after successful send
                count++;
                delay(100);
        } else if ((temp == 0xD8) & (temp_last == 0xFF)) {
            is_header = true;
            buffer[buffer_index++] = temp_last;
        if ((temp == 0xD9) && (temp_last == 0xFF)) { // JPEG end marker detected
            if (buffer_index > 0 && !send_with_retry(buffer, buffer_index)) {
                Serial.println(F("Failed to send last packet."));
                myCAM.CS_HIGH();
                return 0;
    Serial.print(F("Total packets sent: "));
    Serial.println(count);
    myCAM.CS_HIGH();
    Serial.println(F("Transmission ended."));
    delay(100000);
    return 1;
bool send_with_retry(uint8_t *buffer, size_t len) {
    int retryCount = 0;
    while (retryCount < 3) {
        if (nrf24.send(buffer, len)) {
            return true;
        Serial.println(F("Retry sending packet..."));
        delay(100);
        retryCount++;
    return false;
heres the server code
#include <SPI.h>
// Include SD card library when you're ready to implement it
#include <SD.h>
RH_NRF24 nrf24;
const int chipSelect = 4;
  while (!Serial) ; // Necessary for Leonardo only
  if (!nrf24.init()) {
  // Set radio channel and RF settings
  if (!nrf24.setChannel(1)) {
  if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm)) {
  // Initialize SD card when you're ready
   //if (!SD.begin(chipSelect)) {
     //Serial.println("SD Card initialization failed!");
int count = 0;
  if (nrf24.available()) {
    int length = 32;
    uint8_t buf[length];
    uint8_t len = sizeof(buf);
    if (nrf24.recv(buf, &len)) {
      count++;
      // Print each byte in a formatted way
      Serial.print("Packet ");
      Serial.print(": ");
      for (int i = 0; i < len; i++) {
        Serial.print(buf[i], HEX);
        Serial.print(" ");
        // Check for JPEG end marker
        if (i > 0 && (buf[i] == 0xD9) && (buf[i - 1] == 0xFF)) {
          Serial.println("\nJPEG End Found");
          Serial.print("Total Packets: ");
          count = 0;
          // When ready, save or handle the complete image data
          // saveImageDataToSD(buf, len);
      Serial.println("Receive failed");
heres an example of the currupted data
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
