Trying to set RTC and get compilation problem
Hi All, I'm getting this error trying tu use simple examples of RTC library with 3231 rtc module and
arduino MKR WiFi 1010
I have no idea what is wrong but I've use these components before without any problems.. the error happens in online editor i'll checkit in the normal ide to see if it behaves differently
In file included from /home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
from /home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.11/cores/arduino/Arduino.h:35,
from /tmp/arduino-build-D0F24A9F48D68B45801BA2C7984B5853/sketch/DS3231_Auto_copy.ino.cpp:1:
/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:487:38: error: expected ')' before '*' token
#define RTC ((Rtc *)0x40001400UL) /**< \brief (RTC) APB Base Address */
/tmp/734976349/DS3231_Auto_copy/DS3231_Auto_copy.ino:5:15: note: in expansion of macro 'RTC'
static DS3231 RTC;
static DS3231 RTC;
thanks in advance for any help on this
Sounds like "RTC" is defined as a macro in the Mkr WiFi 1010 core.
Try changing "RTC" throughout your code to something else such as "myRTC".
Yess, silly me i've not seen that!! Thankyou very much
rtc is defined for the onboard rtc clock and I reuse rtc for the external
Thanks again!
