Hi all,
Let me begin by saying that I am new to both the Arduino hardware and programing. I have been working on it for about a month now to understand and expand my knowledge a bit and I believe I can at least grasp the basic concepts.
I'm using an Arduino Uno board together with some individually addressable LED strips to create a series of independent "paths" where one led would look like it's traveling along its path.
So if we were to look at it in simple "pseudo code" it would be something like:
Blink led 0 once;
Blink led 1 once;
Blink led 2 once;
Restart after reaching the last led
So I managed to code this pretty easily using delay, see below.
#include <Adafruit_NeoPixel.h> //Library in use; needs to be compatible with the LED strip
#define S01PIN 3 // Data pin for strip01
#define S01NUNLEDS 8 // Number of leds for strip01
Adafruit_NeoPixel strip01(S01NUNLEDS, S01PIN, NEO_RGBW + NEO_KHZ800); //strip01 DEFINITIONS
//travel(); DEFINITIONS
#define TLEDON 500 //TIME EACH LED IS ON; IN MILLISECONDS
#define TLEDOFF 0 //TIME BETWEEN ONE LED TURNS OFF AND THE NEXT ONE LIGHTS UP; IN MILLISECONDS
strip01.begin(); // Initializes the strip
strip01.clear(); // Clears the strip of any previous data
travel();
void travel() {
for (int i = 0; i < S01NUNLEDS; i++) {
//This section turns the led ON
strip01.setPixelColor(i, 255, 0, 0);
strip01.show();
delay(TLEDON);
//This section turns the led OFF
strip01.setPixelColor(i, 0, 0, 0);
strip01.show();
delay(TLEDOFF);
The problem comes when I want to use other strips, with different lengths, to have the same effect. For this I can't really use delay (and i've read why you shouldn't be using delay anyway, makes sense really). So, I looked up Demonstration code for several things at the same time and tried to adapt it to my project using the code below.
//---CONSTANTS
#define PIN 3
#define NUNLEDS 8
Adafruit_NeoPixel strip(NUNLEDS, PIN, NEO_RGBW + NEO_KHZ800);
const int travelSpeed = 1000; //Time each led should be ON
const int interval = 500; //Interval between one led turning OFF and the next one turning ON
//---VARIABLES
boolean going = false; //Virtual switch
unsigned long currentMillis = 0; // Stores the value of millis() in each iteration of loop()
unsigned long previousPixelMillis = 0; // will store last time the LED was updated
strip.begin();
strip.clear();
currentMillis = millis();
state();
travel();
void state() {
if (going == false) {
if (currentMillis - previousPixelMillis >= interval) {
going = true;
previousPixelMillis += interval;
else {
if (going == true) {
if (currentMillis - previousPixelMillis >= travelSpeed) {
going = false;
previousPixelMillis += travelSpeed;
void travel() {
for (int i = 0; i < NUNLEDS; i++) {
if (going) {
strip.setPixelColor(i, 0, 255, 0);
strip.show();
else {
strip.setPixelColor(i, 0, 0, 0);
strip.show();
But this makes the whole strip blink and I haven't been able to figure out to create the same effect.
Any help will be greatly appreciated.
Thanks,
