Trying to solve millis problem
Hi guys,
im a first year robotics student from holland and have a small question. Tomorrow i will have a test where i should show some small set of skills. One of them is to let an led blink. With a delay this is very easy ofcourse. But because i want to use a button and i want that on any given time in the code the button can be used to switch to another method (or function) i thought working with the millis(); function was one of the best options.
(problem is in the void blinkRight(), the leds will keep on burning when i push the right button (buttonRight).
Does anyone have an idea why this is happening? And maybe you guys have some more feedback or suggestions! Thanks a lot in advance!
I wrote the following code:
int led2 = 2;
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
int buttonRight = 8;
int buttonLeft = 9;
int state;
unsigned long Timer2;
unsigned long Timer3;
unsigned long Timer4;
unsigned long Timer5;
unsigned long Timer6;
unsigned long Timer7;
long previousMillis2 = 0;
long previousMillis3 = 0;
long previousMillis4 = 0;
long previousMillis5 = 0;
long previousMillis6 = 0;
long previousMillis7 = 0;
long interval = 1000;
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
  pinMode(led7, OUTPUT);
  pinMode(buttonRight, INPUT);
  pinMode(buttonLeft, INPUT);
    digitalWrite(led2, LOW);
    digitalWrite(led3, LOW);
    digitalWrite(led4, LOW);
    digitalWrite(led5, LOW);
    digitalWrite(led6, LOW);
    digitalWrite(led7, LOW);
void blinkRight(){
  while(digitalRead(buttonLeft) != HIGH){
    digitalWrite(led2, HIGH);
    Timer2 = millis();
      if((millis() - Timer2) >= 150){
    digitalWrite(led3, HIGH);
    Timer3 = millis();
      if((millis() - Timer3) >= 150){
    digitalWrite(led4, HIGH);
    Timer4 = millis();
      if((millis() - Timer4) >= 150){
    digitalWrite(led5, HIGH);
    Timer5 = millis();
      if((millis() - Timer5) >= 150){
    digitalWrite(led6, HIGH);
    Timer6 = millis();
      if((millis() - Timer6) >= 150){
    digitalWrite(led7, HIGH);
    Timer7 = millis();
      if((millis() - Timer7) >= 150){
void blinkLeft(){
  while(digitalRead(buttonRight) != HIGH){
    delay(150);
    delay(150);
    delay(150);
    delay(150);
    delay(150);
    delay(150);
// the loop routine runs over and over again forever:
  if(digitalRead(buttonRight) == HIGH){
    blinkRight();
  } else if(digitalRead(buttonLeft) == HIGH){
    blinkLeft();
    Timer2 = millis();
Lets say the value returned by millis() is 100. What will the value of "millis() - Timer2" be? Let's say its 1,000, 10,000, 100,000, etc. How can the result of that if statement ever be true?
Hi!
Thank you for your reply.
So the method millis(); will be only checked there when the code is running there.
I hoped the millis(); function would be checked at anytime the application is running.
Now i still dont know how i can make a button which can be pressed at any given moment..
Lets say i want to make a circle of LED's which will blink one for one. But at any given moment when these LED's are making a circle of blinks i want to be able to press a button which will make them start from the other side... Do you have any ideas for me?
Once again,
i'm really thankfull for your help
Zzasr:
What code running where? Maybe try rephrasing this
millis() is updated in the “background”. It’s “checked” whenever you call it.
Now i still dont know how i can make a button which can be pressed at any given moment…
What is physically limiting you from pressing the button? I’ve never come across a button that limits itself from being pressed at certain times. Maybe try rephrasing this too.
BlinkWithoutDelay example shows you how to blink a single LED without blocking code. Combine this with a finite state machine that keeps track of which LED should be turned on next will led you build a sequence out of this.
Outside of all that code, you can poll the buttons and make adjustments to the parameters of the finite state machine. Simple pseudo code:
if its been long enough
  turn the current led off
  turn the next led on
  set the next led to the current led
  set the last change time to now
if button1 is pushed
  set the next led to current led + 1
else if button2 is pushed
  set the next led to current led - 1
Thank you for your help. Im now going off to bed. Its 1:37 AM over here. I almost got it working now. Thank you for your help, it was really usefull! I'll let you know how it went tomorrow!
Greetings from Holland!
