Trying to trigger second neopixel led strip before second one
Im trying to trigger a second neopixel ledstrip "count up" before the other, but i can't get my code to compile. Im trying to do it with a function that's triggered in the other function.
Here's the code
#ifdef __AVR__
#include <avr/power.h>
#endif
const byte ledPin=D5;
const byte led2Pin=D3;
#define NUMPIXELS      12
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, ledPin, led2Pin, NEO_GRB + NEO_KHZ800);
int delayval = 700; // Vertraging voetstappen
int inPin = D7;   // Input pushbutton
int val = 0;     // variable for reading the pin status
const int GREEN = D1;
  pinMode(ledPin, OUTPUT);  // declare LED as output
  pinMode(led2Pin, OUTPUT);  // declare LED 2 as output
  pinMode(inPin, INPUT);    // declare pushbutton as input
  //pinMode(D1, OUTPUT);
 analogWrite(GREEN, 255);
  val = digitalRead(inPin);  // read input value
  if (val == HIGH)
  {         // check if the input is HIGH (button released)
    Serial.println("HOOOOOG");
    SetPixels();
    //digitalWrite(ledPin, LOW);
  } /*else {
    digitalWrite(ledPin, HIGH);
        Serial.println("laag");
void runfirst() {
  for (int i = 0; i < NUMPIXELS; i++)
    // pixels.Color takes RGB values, from 255,0,0 up to 0,255,255w
    pixels.setPixelColor(i, pixels.Color(0, 255, 0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
void SetPixels()
  runfirst();
Which board are you using ?
An ESP8266 perhaps as you are using D1, D3, D5 and D7 as pin numbers
Please post the complete text of the error messages that you get
Hey Bob.
Im using the NodeMCU which indeed has d1, d2 and such
Here's the error that i got
Arduino: 1.8.6 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Beyond_S:11:94: error: no matching function for call to 'Adafruit_NeoPixel::Adafruit_NeoPixel(int, const byte&, const byte&, int)'
/Users/Owner/Documents/Arduino/Beyond_S/Beyond_S.ino:11:94: note: candidates are:
In file included from /Users/Owner/Documents/Arduino/Beyond_S/Beyond_S.ino:1:0:
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:122:3: note: Adafruit_NeoPixel::Adafruit_NeoPixel()
   Adafruit_NeoPixel(void);
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:122:3: note:   candidate expects 0 arguments, 4 provided
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:121:3: note: Adafruit_NeoPixel::Adafruit_NeoPixel(uint16_t, uint8_t, neoPixelType)
   Adafruit_NeoPixel(uint16_t n, uint8_t p=6, neoPixelType t=NEO_GRB + NEO_KHZ800);
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:121:3: note:   candidate expects 3 arguments, 4 provided
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:116:7: note: constexpr Adafruit_NeoPixel::Adafruit_NeoPixel(const Adafruit_NeoPixel&)
 class Adafruit_NeoPixel {
/Users/Owner/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:116:7: note:   candidate expects 1 argument, 4 provided
exit status 1
Board at /dev/cu.SLAB_USBtoUART is not available
option enabled in File -> Preferences.
The error message is telling you that the library has no function that rakes two LED pins as parameters in the way that you tried
You can, however, create more than one NeoPixel object each with its own name and LED pin
Adafruit_NeoPixel pixels1 = Adafruit_NeoPixel(NUMPIXELS, led1Pin, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel pixels2 = Adafruit_NeoPixel(NUMPIXELS, led2Pin, NEO_GRB + NEO_KHZ800);
Then you can control any LED in either by using the name of the required NeoPixel object
UKHeliBob:
Sweet! that was quite a simple fix, thanks Bob :slight_smile:
