Trying to turn off a 4 devices and their status f lags with 1 input button
// declare variables
int     ledPin = 6;                // LED1
int     heatpin = 7;               // ANTENNA
int     aedpin = 5;                // LED3
int     fedpin = 8;                // fE PWR
int     medpin = 9;                // me - anolog pin 9 for fan control
int     sensorPin = A0;            // analog in 0 forlight sense
int     sensorValue = 0;           // integer for the analog sensor
int     PIRstate = 0;              // variable for PIR sensor status
int     PIR = 2;                   // PIR sensor is connected to digital pin 2
int     motorlevel = 0;                // motor
String  readString = String(30);   // string for fetching data from address
boolean LEDON = false;             // LED1 status flag
boolean HEDON = false;             // ANTENNA status flag
boolean AEDON = false;             // led3 status AE
boolean FEDON = false;             // power FE pin status
boolean MEDON = false;            // status off
boolean MEDON1 = false;            //MED SPEED STATUS ON
boolean PEDON = false;              // all devices status off
  Ethernet.begin(mac, ip, gateway, subnet ); //start Ethernet
  pinMode(ledPin, OUTPUT); //Set pin 6 to output
  pinMode(heatpin, OUTPUT); // set pin 7 to output
  pinMode(aedpin, OUTPUT); // set pin 5 to output
  pinMode(fedpin, OUTPUT); // set pin 8 to output
  pinMode(PIR, INPUT); // set pir to input
  pinMode(medpin, OUTPUT); // set pin a3 to output
  sensorValue = analogRead(sensorPin);
[code]
 EthernetClient client = server.available();  // Create a client connection
  if (client) {
    boolean current_line_is_blank = true; //new
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if we've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // send a reply
        if (readString.length() < 30) { //read char by char HTTP request
          readString.concat(c);
        } //store characters to string
// HTML Code
if (c == '\n' && current_line_is_blank) {
          // HTML Code
          client.println(F("HTTP/1.1 200 OK")); //output HTML data starting with standard header
          client.println(F("Content-Type: text/html"));
          client.println();
          client.print(F("<body style=background-color:BLACK>")); //set background to BLACK
          // Auto refresh webpage every 60 seconds
          client.println(F("<META HTTP-EQUIV=REFRESH CONTENT=60 URL=>"));
          client.println("<center>");
          client.println(F("<font color=’green’><h1>INTERNET -- CONTROL </font></h1>/"));//send first heading
          client.println(F("<hr />"));
          client.println(F("<font color=’#0D8112’ size=’5?> "));
          client.println("</center>");
          motorlevel = 0;
  //indexOf("L=")
        if (c == '\n') { //if HTTP request has ended
          int Le = readString.indexOf("L="); //led here is a key component of where
          int He = readString.indexOf("H="); //the status is being read by the arduino
          int Ae = readString.indexOf("A=");
          int Fe = readString.indexOf("F=");
          int Me = readString.indexOf("M="); //motor / fan
          int Pe = readString.indexOf("P="); //master all OFF
     // Check if anything  should be lighted or turned on
            if (Le > 1){
            if (readString.substring(Le,(Le+3)) == "L=1") { //led has to be turned ON
              digitalWrite(ledPin, HIGH); // set the LED on
              LEDON = true;
            if (readString.substring(Le,(Le+3)) == "L=0") {
              //led has to be turned OFF
              digitalWrite(ledPin, LOW); // set the LED OFF
              LEDON = false;
// all power to off check
if (Pe > 1){
           if (readString.substring(Pe,(Pe+3)) == "P=0") { //ALL OFF
            motorlevel = 0;
            analogWrite(medpin, motorlevel); // set the LED1 off
            digitalWrite(heatpin, LOW); // set the heat OFF
           digitalWrite(aedpin, LOW); // set the ANT OFF
           digitalWrite(fedpin, LOW); // set the PWR OFF
           PEDON = true;
           client.print(F("<form method=get name=LED>"));
           client.print(F("<input type='radio' name='L' value='1'>LED1 ON
           client.print(F("<input type='radio' name='L' value='0'>LED1 OFF
           client.print(F("<input type='radio' name='P' value='0'>ALL OFF
           client.println(F("<input type=submit value=submit></form>"));
// DETERMINE WHAT STATUS TO PRINT
          client.print(F("<font size=’5?>LED1 status: "));
          if (LEDON == true) {
            client.println(F("<font color='#FF0000' size=’5?>ON</font>")); //red
          else {
            client.println(F("<font color='#0099FF' size=’5?>OFF</font>")); //blue
// check for all off status condition, if so turn all status flags  to off
           if (PEDON == true) {
           LEDON = false;             // LED1 status off
           HEDON = false;             // ANTENNA status off
           AEDON = false;             // led3 status AE off
           FEDON = false;             // power FE pin status off
            MEDON = false;
            MEDON1 = false;            // off
  1. code is used to turn on /off several devices by using the input button commands - this works
    I did not include all the device code as it might be to long to post
Problem:
I am trying to add another input command which would turn all devices and their status off at once.
Joe
[/code]
Problem:
Sorry but I don't understand what your problem is.
You have commands to switch thing individually, well just have an other command that turns all the devices off.
