#include "DHT.h"
String password = "80";
int arrivingdatabyte;
#define DHTPIN 4
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
pinMode(13, OUTPUT);
Serial.println(F("DHTxx test!"));
dht.begin();
delay(2000);
float h = dht.readHumidity();
float t = dht.readTemperature();
float f = dht.readTemperature(true);
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
float hif = dht.computeHeatIndex(f, h);
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(hif);
Serial.println(F("°F"));
while (Serial.available() == 1) {
String input = Serial.readString();
if (input == "80") {
digitalWrite(13, LOW);
if (input == "78") {
digitalWrite(13, HIGH);
Your code will not compile. Please post the complete code.
Please read the forum guidelines](How to get the best out of this forum) to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please go back and fix your original post.
Looks like you are ignoring what you get from the sensor.
The only thing that turns on/off the LED is information that you receive from the serial monitor.
Should probably be readStringUntil('\r');
What is this for?
i really have no idea im completely new and dont have enough time if i need new code thats fine as long as i can set the temp parameters
see when this reads 80 or higher i need the led to turn off
Dude... you really should have paid more attention in class.
You need an "if" statement.
if (hif > 80)
// Do something
// Do the other thing
i didnt really do classes this is for a project
did i do it right because im getting an error
#include "DHT.h"
#define DHTPIN 4
dht.begin();
delay(2000);
return;
Serial.print(hif);
while (Serial.available()) {
if (hif >= "80") {
else (hif <= "78") {
hif is a float... lose the quotes. (")
C:\Users\Alex\Documents\Arduino\sketch_jan15a\sketch_jan15a.ino: In function 'void loop()':
C:\Users\Alex\Documents\Arduino\sketch_jan15a\sketch_jan15a.ino:60:11: error: invalid operands of types 'float' and 'const char [3]' to binary 'operator>='
if (hif >= "80") {
C:\Users\Alex\Documents\Arduino\sketch_jan15a\sketch_jan15a.ino:64:13: error: invalid operands of types 'float' and 'const char [3]' to binary 'operator<='
exit status 1
Compilation error: invalid operands of types 'float' and 'const char [3]' to binary 'operator>='
See post #10
alright one sec
alright well the error is gone but once it hits past 80 it doesnt turn off
#include "DHT.h"
#define DHTPIN 4
dht.begin();
delay(2000);
return;
Serial.print(hif);
if (hif < 80) {
else (hif > 78); {
Should this be > 80 ?
Should this be < 78 ?
Get rid of the ";"
still doesnt turn off and if i get rid of the ; i get
C:\Users\Alex\Documents\Arduino\sketch_jan15a\sketch_jan15a.ino:64:19: error: expected ';' before '{' token
else (hif < 78) {
exit status 1
Compilation error: expected ';' before '{' token
should be
else if (hif < 78) {
Post your latest code in full
thanks works now
#include "DHT.h"
#define DHTPIN 4
dht.begin();
delay(2000);
return;
Serial.print(hif);
if (hif > 80) {
What is this code for? It does nothing.
really? huh yea
You do nothing with "input" ... if you don't need it get rid of it.
