Anyone help with this code query. I got the code from Sparkfun somewhere.
Cut pasted as is. When I validate it flags
’resetEDPins’ cannot be used as a function
I can see that it is declared as a variable, and called as a function. I don’t know why, and am not sure which one to remove or amend. Any pointers?
Ta.
//Declare pin functions on Redboard
#define stp 2
#define dir 3
#define MS1 4
#define MS2 5
#define EN 6
//Declare variables for functions
char user_input;
int x;
int y;
int state;
int resetEDPins;
pinMode(stp, OUTPUT);
pinMode(dir, OUTPUT);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(EN, OUTPUT);
resetEDPins(); //Set step, direction, microstep and enable pins to default states
Serial.begin(9600); //Open Serial connection for debugging
Serial.println(“Begin motor control”);
//Print function list for user selection
Serial.println(“Enter number for control option:”);
Serial.println(“1. Turn at default microstep mode.”);
Serial.println(“2. Reverse direction at default microstep mode.”);
Serial.println(“3. Turn at 1/8th microstep mode.”);
Serial.println(“4. Step forward and reverse directions.”);
//Main loop
while(Serial.available()){
user_input = Serial.read(); //Read user input and trigger appropriate function
digitalWrite(EN, LOW); //Pull enable pin low to allow motor control
if (user_input ==‘1’)
StepForwardDefault();
else if(user_input ==‘2’)
ReverseStepDefault();
else if(user_input ==‘3’)
SmallStepMode();
else if(user_input ==‘4’)
ForwardBackwardStep();
Serial.println(“Invalid option entered.”);
resetEDPins();
//Default microstep mode function
void StepForwardDefault()
Serial.println(“Moving forward at default step mode.”);
digitalWrite(dir, LOW); //Pull direction pin low to move “forward”
for(x= 1; x<1000; x++) //Loop the forward stepping enough times for motion to be visible
digitalWrite(stp,HIGH); //Trigger one step forward
delay(1);
digitalWrite(stp,LOW); //Pull step pin low so it can be triggered again
delay(1);
Serial.println(“Enter new option”);
//Reverse default microstep mode function
void ReverseStepDefault()
Serial.println(“Moving in reverse at default step mode.”);
digitalWrite(dir, HIGH); //Pull direction pin high to move in “reverse”
for(x= 1; x<1000; x++) //Loop the stepping enough times for motion to be visible
delay(1);
delay(1);
// 1/8th microstep foward mode function
void SmallStepMode()
Serial.println(“Stepping at 1/8th microstep mode.”);
digitalWrite(MS1, HIGH); //Pull MS1, and MS2 high to set logic to 1/8th microstep resolution
digitalWrite(MS2, HIGH);
delay(1);
delay(1);
//Forward/reverse stepping function
void ForwardBackwardStep()
Serial.println(“Alternate between stepping forward and reverse.”);
for(x= 1; x<5; x++) //Loop the forward stepping enough times for motion to be visible
//Read direction pin state and change it
state=digitalRead(dir);
if(state == HIGH)
else if(state ==LOW)
digitalWrite(dir,HIGH);
for(y=1; y<1000; y++)
delay(1);
delay(1);
Serial.println(“Enter new option:”);
