Trying to understand Arduino Serial and C++ arrays
Hello everyone,
I've done a bit of programming for the Arduino before, but I'm not well versed in the C++ language. I come from the C# world, and I found a behaviour that is utterly alien to me.
I want to share my sketch and my serial output with you in the hope that you can enlighten me as to why I get those very strange values when I write to the last element in the char array.
The sketch is just a way to adjust the time between the blinks by sending a message through the serial port. It should be a string of the type "a__v____" ending in \n.
int ledPin = 13;
char blinkStr[4] = {0};
char pinNo[2] = {0};
char b[9];
int i = 0;
unsigned long blinkStep = 2000UL;
unsigned long blinkTime = 200UL;
unsigned long nextStep = 0UL;
bool ledStatus = false;
  Serial.setTimeout(5000);
  pinMode(ledPin, OUTPUT);
  if (Serial.available())
    b[i] = Serial.read();
    i++;
    if (i == 9 || b[i - 1] == '\n' || b[i - 1] == '\r')
      if ((char)b[0] == 'a' && (char)b[3] == 'v')
        pinNo[0] = b[1];
        pinNo[1] = b[2];
        int newPin = atoi(pinNo);
        ledPin = newPin;
        Serial.print(blinkStr);
        Serial.print(" ");
        Serial.println(blinkStr[0]);
        blinkStr[0] = b[4];
        Serial.print(" ");
        blinkStr[1] = b[5];
        Serial.print(" ");
        Serial.println(blinkStr[1]);
        blinkStr[2] = b[6];
        Serial.print(" ");
        Serial.println(blinkStr[2]);
        blinkStr[3] = b[7];
        Serial.print(" ");
        Serial.println(blinkStr[3]);
        int newDuration = atoi(blinkStr);
        blinkStep = newDuration;
        Serial.print("New step for pin ");
        Serial.print(pinNo);
        Serial.print(" is ");
        Serial.println(blinkStr);
        Serial.print("Parsed values are ");
        Serial.print(newPin);
        Serial.print(" and ");
        Serial.println(newDuration);
        Serial.print("Bad buffer syntax: ");
        Serial.println(b);
      i = 0;
  // blink loop
  if ((long)(millis() - nextStep) >= 0)
    if (ledStatus == false)
      digitalWrite(ledPin, HIGH);
      ledStatus = true;
      nextStep += blinkTime;
      digitalWrite(ledPin, LOW);
      ledStatus = false;
      nextStep += blinkStep - blinkTime;
Now the fun part comes when I show you the serial output for "a13v1500":
1 1
15 5
150 0
150013a13v1500
	 0
New step for pin 13a13v1500
	 is 150013a13v1500
Parsed values are 13 and 18941
As you can see, the blinkStr values ar perfectly ok until I write to the last position, at which point something leaks and I get blinkStr, pinNo and the whole b array in one go. Of course, after parsing the value it wraps around the maximum integer vaule a few times and ends up at 18941.
My question is simple, why does this happen? I can prevent this by increasing their size by 1 (blinkStr[5] pinNo[3]) but I don't understand why this happens. I mean the array is of size 4. not of size 4+2+9. Why would their values leak into each other?
int newPin = atoi(pinNo);atoi accepts a string, doesn't it?
As far as I understand it, a string is actually a null terminated char array. As opposed to a String which is an object. And atoi() accepts my char array.
I'm guessing that my pinNo[2] and blinkStr[4] have no room for the final null character so they leak into each other. And that's why when I change to pinNo[3] and blinkStr[5] they work.
Thanks for the pointer.
simplethemind:
...and thank you for accepting it, and figuring it out
