trying to understand custom characters and the 8_bit format[SOLVED]
hello arduino community , i love you guys! well when we want to create custom characters we create an array of 7 bytes (or 8 bytes) . all of them start with letter B , for example 0B00000 well i understand what the digits on the right of the letter B are for , but not the letter B itself and the zero to its left , i dont understand what they mean and why we put them there . also i found a converter from character to byte code and the conversion did not give me no letter B , so is it something specific to the arduino language ?
The initial zero is there to inform the compiler that this is a number. The 'B' tells the compiler that this is a 'Binary' number.
Don
There are 3 common ways to show data: 1) show each bit individually, BIN format 0b01011010 or B01011010, shows bit 7 on the left (MSB) and 0 on the right (LSB)
2) show the data in HEX format 0x5A (0101 is 5, 1010 is A). 0b00000000 = 0x00 0b00000001 = 0x01 0b00000010 = 0x02 0b00000011 = 0x03 0b00000100 = 0x04 0b00000101 = 0x05 0b00000110 = 0x06 0b00000111 = 0x07 0b00001000 = 0x08 0b00001001 = 0x09 0b00001010 = 0x0A 0b00001011 = 0x0B 0b00001100 = 0x0C 0b00001101 = 0x0D 0b00001110 = 0x0E 0b00001111 = 0x0F
3) show the data in Decimal format 0x00 thru 0x0F = 0 to 15 0x00 thru 0xFF = 0 to 255
Depending on what you are doing, one format might be better over another. When designing hardware, I often think in binary terms to make it easier to visualize bit placement. Same for HEX - when looking at data coming from devices, manipulating it to combine nibbles (1/2 upper or lower 4 bits in a byte), it can be easier to see the data in HEX format.
Decimal - 0 to 255 just doesn't tell you much about the data.
The compiler will give you errors if you have too many binary bits, or not enough hex digits.
http://arduino.cc/en/Reference/IntegerConstants
What's this have to do with "crystal library library"?
thank you guys
