I have made a sketch for the ESP8266 that reads my electricity meter through an MBUS to ttl converter.
The program works fine, but I would like to understand the serial read process better than I do. So I made a small sketch that shows how data is read, and counts the number of times the loop calls the read function in the sketch before there is a message present.
The meter only outputs at 2400 bd, but the serial buffer is checked (that's how I understand it anyway) many times before each complete message. (Serial.available() > 0) is a condition to start reading.
The telegrams are 41 and 123 bytes long respectively, and seems complete every time they are read.
What puzzles me is: Every time data is reported, it seems to be a complete message and not parts of a message. I would expect that many times only part of a message would be read, because the baudrate is low and the loop seems to run very fast.
Could someone please explain why only complete messages are reported, and not parts of messages?
Code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 14); // RX, TX
unsigned char buf[4096];
int buf_len = 0;
boolean newData = false;
int readCount = 0;
// Wait 1 second
// Serial reads the meter
Serial.begin(2400, SERIAL_8E1);
// mySerial prints to the monitor
mySerial.begin(57600);
Serial.swap();
readDataTelegram();
if (newData == true) {
mySerial.print("readDataTelegram() run: ");
mySerial.print(readCount + 1);
mySerial.println(" times");
readCount = 0;
mySerial.print("Telegram just read with length (buf_len): ");
mySerial.print(buf_len);
mySerial.println(" bytes");
mySerial.println();
newData = false;
readCount++;
// Read the serial buffer
void readDataTelegram() {
static byte ndx = 0;
char rc;
while ((Serial.available() > 0) && (newData == false)) {
rc = Serial.read();
buf[ndx] = rc;
ndx++;
if (ndx > 0) {
buf_len = ndx;
ndx = 0;
newData = true;
Result:
readDataTelegram() run: 244121 times
Telegram just read with length (buf_len): 41 bytes
readDataTelegram() run: 244650 times
readDataTelegram() run: 294617 times
Telegram just read with length (buf_len): 123 bytes
readDataTelegram() run: 191217 times
readDataTelegram() run: 244589 times
readDataTelegram() run: 244763 times
readDataTelegram() run: 244459 times
readDataTelegram() run: 295225 times
readDataTelegram() run: 191509 times
readDataTelegram() run: 244458 times
readDataTelegram() run: 244591 times
readDataTelegram() run: 244813 times
readDataTelegram() run: 292875 times
What is the maximum value for an 'int' data type on a ESP8266?
1^31 - 1
On the ESP platform the Serial.available() call does not just return the number of bytes in the buffer but also calls optimistic_yield() to do some background tasks. The call is yielding only if the current loop() run is running for more than 10ms. The hardware has an internal buffer that is copied to the ring buffer in an interrupt. I don't know what exactly triggers this copying as I'm not an expert for this processor.
adwsystems:
When ESP8266(NodeNCU1.0-12E Module) is being operated under Arduino IDE, should we shift from the understanding that the value of the int type variable can be from -32768 to 32767.
GolamMostafa:
Then how does read count exceed 32767 per the serial monitor output in the OP? Not using the Arduino IDE?
LOL. 2^31 - 1 is correct if someone didn't catch my error instantly.
When ESP8266(NodeNCU1.0-12E Module) is being operated under Arduino IDE, should we shift from the understanding that the value of the int type variable is from -32768 to 32767.
int is always platform specific. If you use a Due it's 32bit too. If you need a fixed size use the corresponding sized types (int16_t, int32_t, etc.).
pylon:
I am beginning (forcing myself) to use those declarations in order to know (remind me) what size value I'm working with.
