i am trying to understand the nick gammon's Serial State machine code.
the code is
// Example state machine reading serial input
// Author: Nick Gammon
// Date: 17 December 2011
// the possible states of the state-machine
typedef enum { NONE, GOT_R, GOT_S, GOT_G } states;
// current state-machine state
states state = NONE;
// current partial number
unsigned int currentValue;
void setup ()
Serial.begin (115200);
state = NONE;
} // end of setup
void processRPM (const unsigned int value)
// do something with RPM
Serial.print ("RPM = ");
Serial.println (value);
} // end of processRPM
void processSpeed (const unsigned int value)
// do something with speed
Serial.print ("Speed = ");
} // end of processSpeed
void processGear (const unsigned int value)
// do something with gear
Serial.print ("Gear = ");
} // end of processGear
void handlePreviousState ()
switch (state)
case GOT_R:
processRPM (currentValue);
case GOT_S:
processSpeed (currentValue);
case GOT_G:
processGear (currentValue);
} // end of switch
currentValue = 0;
} // end of handlePreviousState
void processIncomingByte (const byte c)
if (isdigit (c))
currentValue *= 10;
currentValue += c - '0';
} // end of digit
// The end of the number signals a state change
handlePreviousState ();
// set the new state, if we recognize it
switch (c)
case 'R':
state = GOT_R;
case 'S':
state = GOT_S;
case 'G':
state = GOT_G;
default:
state = NONE;
} // end of switch on incoming byte
} // end of not digit
} // end of processIncomingByte
void loop ()
while (Serial.available ())
processIncomingByte (Serial.read ());
// do other stuff in loop as required
} // end of loop
as a newbie.. i am having hard time understanding it.
can someone explain / simplify the following
does enum is used to define states?
what's the use of typedef and states?
case GOT_S:
case GOT_G:
what is the currentValue passing to the function?
i barely understand the flow but dont understand how it is getting the data into variable Value. can Someone explain it..
