Hi, I wonder if someone could help me, please. I'm trying to convert the following MicroPython functions into Arduino code but I'm not sure what the pack() function is doing. I tried to read up on it, but it does not make sense to me!
def encrypt(string):
key = 123
result = pack(">I", len(string))
for i in string:
a = key ^ ord(i)
key = a
result += bytes([a])
return result
def decrypt(string):
key = 123
result = ""
for i in string:
a = key ^ i
key = i
result += chr(a)
return result
pack() seems to be roughly equivalent to "sprintf()", so the code looks like it makes an "encrypted" string with the length specified at the beginning. (but that's not very consistent with the defintion of decrypt(), which doesn't seem to know anything about a length.)
You can't put arbitrary binary bytes in a String so you need to provide a byte array for the encrypted data. It has to be large enough to hold the characters in the string plus four bytes of length.
Note: I had a mistake in the decrypt function. Fixed below.
void encrypt(String &string, byte *buffer)
uint32_t len = string.length();
// First 4 bytes are length in BigEndian format
buffer[0] = (len >> 24) & 0xFF;
buffer[1] = (len >> 16) & 0xFF;
buffer[2] = (len >> 8) & 0xFF;
buffer[3] = len & 0xFF;
byte key = 123;
for (size_t i = 0; i < len; i++)
key = string[i] ^ key;
buffer[i + 4] = key;
String decrypt(byte *buffer)
uint32_t len = (uint32_t)buffer[0] << 24
| (uint32_t)buffer[1] << 16
| buffer[2] << 8
| buffer[3];
String string;
byte key = 123;
string += (char) (buffer[i+4] ^ key);
key = buffer[i+4];
return string;
delay(200);
String cmd = "Hello";
Serial.println(cmd);
byte buffer[cmd.length() + 4];
encrypt(cmd, buffer);
for (size_t i=0; i< sizeof buffer; i++)
Serial.print(buffer[i], HEX);
Serial.print(' ');
Serial.println(decrypt(buffer));
void loop() {}
Thank you for clearing that up for me. I appreciate your time and effort. I kind of understood I needed a buffer to hold the data, I just wasn't sure how to work out the size or what type it was.
