Hello forum,
I haven't used Arduino in a while but was excited when I saw that my SeeMeCNC Rostock Max V2 3D printer required its use for uploading the board; it's great to see that Arduino being used on something new! However, I followed the instructions for the firmware upload to a "t" and have run into an unfortunate error.
When I go to upload the Repetier software to my RAMBo controller, which is a glorified Mega 2560, I get the following error:
Arduino: 1.6.7 Hourly Build 2015/11/17 06:13 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}", automatically converted to recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{preprocessed_file_path}". Consider upgrading this core.
sketch/libraries/twi.c:1:17: fatal error: twi.c: No such file or directory
#include <twi.c>
compilation terminated.
exit status 1
Error compiling.
enabled in File > Preferences.
How do I fix this? My first idea is that I started using the 1.6.6 build and the instructions call for 1.6.1 (although they say this shouldn't be a problem). Even in downloading the older version, from which this error code is from, it says "Arduino 1.6.7". Is it not possible to use 1.6.1?
My second idea is that maybe I need to update or refresh the libraries. I am on Mac OS X and saw some instructions for removing the libraries file Windows but it didn't specify anything for Mac. I also used the board manager and tried versions 1.6.2, 1.6.8, and 1.6.9 (didn't work at all) and nothing changed anything.
Does anyone have any other ideas? Thanks for any help!
