Trying to use a 74HC595 Serial Register to control a display PLZ HELP
Trying to use a 74HC595 in this example
for a project in my class and I keep getting this error and I do not know why
exit status 1
expected ‘}’ before numeric constant
const int latchPin = 12; // pin 12 connected to ST_CP of the 74HC595
const int clockPin = 8;  // pin 8 connected to SH_CP of the 74HC595
const int dataPin = 11;  // pin 11 connected to DS of 74HC595
//display 0,1,2,3,4,5,6,7,8,9,A,b,c,d,E,F
int Array[] = {252, 96. 218, 242, 102, 182, 190, 224, 254, 246, 238, 62, 156, 122, 158, 142};
  // set pins to ouput
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  // loop from 0 to 256
  for(int num = 0; num < 16; num++)
    digitalWrite(latchPin, LOW); // set latch pin to low and hold at low for as long as transmission lasts
    shiftOut(dataPin,clockPin,MSBFIRST,Array[num];
    // return the latch pin to high to signal that it no longer needs to listen for information
    digitalWrite(latchPin, HIGH);
    delay(1000);  // wait for one second
You should post the complete error message. It included line numbers and all that to make it easy to find. Don't paraphrase.
IN this case though it stands out like a sore thumb.
Looks like you lost something on the end there. Every ( needs a ).
Oh wait, I hit the next error. The one you posted was here:
One of those commas is a fraud.
here is the complete error message
Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
sketch_jun09a:5: error: expected ‘}’ before numeric constant
int Array = {252, 96. 218, 242, 102, 182, 190, 224, 254, 246, 238, 62, 156, 122, 158, 142};
C:\Users\noah-\Documents\Arduino\sketch_jun09a\sketch_jun09a.ino:5:25: warning: narrowing conversion of ‘9.6e+1’ from ‘double’ to ‘int’ inside { } [-Wnarrowing]
sketch_jun09a:5: error: expected ‘,’ or ‘;’ before numeric constant
sketch_jun09a:5: error: expected declaration before ‘}’ token
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
and also I fixed the things you pointed out and now its working lol. Im too tired to code lol thanks
  1. // . should be a comma
shiftOut(dataPin,clockPin,MSBFIRST,Array[num]); // closing bracket was missing
Leo…
Wawa:
96. // . should be a comma
Leo…
Where I’m from, ( and ) are called parenthesis not brackets and brackets are [ and ]
— bill
Sorry, confused with parenthesis after the bracket. Need more coffee. Leo..
The paren after the bracket is needed to match the open paren in shiftOut(
