Trying to use a delay for timer with reset
Hello!
I´m trying to make some code, that when i put a high signal on pin 9. I will get a 5v signal out on pin 10 and 12 for 18 seconds, and if it goes low for 5 sec then high again, i want 18 new seconds.
But when i give the signal on pin 9. the pin 10 and 12 to go high in 10 sec, and if i turn on the signal on pin 9,
then waiting 5 sec and then the signal on pin 9 get high again. Then it only gives my 5 sec.
Can someone get me in the right direction? I think i have to do something that reset the timer.
  //start serial connection
  pinMode(9, INPUT_PULLUP);
  pinMode(10, OUTPUT);
  pinMode(12, OUTPUT);
  //read the pushbutton value into a variable
  int sensorVal = digitalRead(9);
  Serial.println(sensorVal);
  if (sensorVal == LOW) {
    digitalWrite(12, LOW);
    digitalWrite(10, LOW);
  else {
    digitalWrite(10, HIGH);
    digitalWrite(12, HIGH);
    delay(18000);
You don't have any code to check if the pin goes LOW and to prevent a new timing sequence until that happens.
Something like this
if (waitingForHigh == true) {
  if (sensorVal == HIGH) {
    waitingForHigh = false;
    // set pins HIGH
    // start timer
else {
      waitingForHigh = true;
I hope I have got this right - my brain feels like porridge right this minute :slight_smile:
...R
