Trying To Use a UV Sensor to control a Servo
I’m working on an Arduino Uno for an engineering project. I’m trying to use the values from a UV sensor breakout to control a servo like a knob. I was able to correctly set everything up. I am able to read the values from the UV sensor using analog read, but am having trouble using it to control the sensor. The issue is that I can’t program my way out of a paper bag, so I’m stuck at this stage of my project. If anyone could offer me any help or advice at all, that would be greatly appreciated.
//Hardware pin definitions
int UVOUT = A0; //Output from the sensor
int REF_3V3 = A1; //3.3V power on the Arduino board
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int UVpin = 0; // analog pin used to connect the potentiometer
int runningValue; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(UVOUT, INPUT);
pinMode(REF_3V3, INPUT);
Serial.println("MP8511 example");
int uvLevel = averageAnalogRead(UVOUT);
int refLevel = averageAnalogRead(REF_3V3);
//Use the 3.3V power pin as a reference to get a very accurate output value from sensor
float outputVoltage = 3.3 / refLevel * uvLevel;
float uvIntensity = mapfloat(outputVoltage, 0.99, 2.9, 0.0, 15.0);
Serial.print("MP8511 output: ");
Serial.print(uvLevel);
Serial.print(" MP8511 voltage: ");
Serial.print(outputVoltage);
Serial.print(" UV Intensity (mW/cm^2): ");
Serial.print(uvIntensity);
delay(150);
//Takes an average of readings on a given pin
//Returns the average
int averageAnalogRead(int pinToRead)
byte numberOfReadings = 8;
unsigned int runningValue = 0;
for(int x = 0 ; x < numberOfReadings ; x++)
runningValue += analogRead(pinToRead);
runningValue /= numberOfReadings;
return(runningValue);
//The Arduino Map function but for floats
//From: http://forum.arduino.cc/index.php?topic=3922.0
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x ­ in_min) * (out_max ­ out_min) / (in_max ­ in_min) + out_min;
runningValue = analogRead(UVpin); // reads the value of the potentiometer (value between 0 and 1023)
runningValue = map(runningValue, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(runningValue); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
Describe the problem.
jremington:
The problem, obviously, is that the value from the sensor is never actually used to move the servo.
Yes, I see now. There is that "return" in front of the code that would have moved the servo...
