Trying to use an RFID weigand 26bit reader but program hangs
I am trying to setup a door access system with a 26bit weigand reader I grabbed off ebay (Link). I dont really know much about weigand, so I grabbed this sketch off another forum post.
 * HID RFID Reader Wiegand Interface for Arduino Uno
 * Written by Daniel Smith, 2012.01.30
 * www.pagemac.com
 * This program will decode the wiegand data from a HID RFID Reader (or, theoretically,
 * any other device that outputs weigand data).
 * The Wiegand interface has two data lines, DATA0 and DATA1.  These lines are normall held
 * high at 5V.  When a 0 is sent, DATA0 drops to 0V for a few us.  When a 1 is sent, DATA1 drops
 * to 0V for a few us.  There is usually a few ms between the pulses.
 * Your reader should have at least 4 connections (some readers have more).  Connect the Red wire
 * to 5V.  Connect the black to ground.  Connect the green wire (DATA0) to Digital Pin 2 (INT0).
 * Connect the white wire (DATA1) to Digital Pin 3 (INT1).  That's it!
 * Operation is simple - each of the data lines are connected to hardware interrupt lines.  When
 * one drops low, an interrupt routine is called and some bits are flipped.  After some time of
 * of not receiving any bits, the Arduino will decode the data.  I've only added the 26 bit and
 * 35 bit formats, but you can easily add more.
#define MAX_BITS 100                 // max number of bits
#define WEIGAND_WAIT_TIME  3000      // time to wait for another weigand pulse.
unsigned char databits[MAX_BITS];    // stores all of the data bits
unsigned char bitCount;              // number of bits currently captured
unsigned char flagDone;              // goes low when data is currently being captured
unsigned int weigand_counter;        // countdown until we assume there are no more bits
unsigned long facilityCode=0;        // decoded facility code
unsigned long cardCode=0;            // decoded card code
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0()
  //Serial.print("0");   // uncomment this line to display raw binary
  bitCount++;
  flagDone = 0;
  weigand_counter = WEIGAND_WAIT_TIME;
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1()
  //Serial.print("1");   // uncomment this line to display raw binary
  databits[bitCount] = 1;
  bitCount++;
  flagDone = 0;
  pinMode(13, OUTPUT);  // LED
  pinMode(2, INPUT_PULLUP);     // DATA0 (INT0)
  pinMode(3, INPUT_PULLUP);     // DATA1 (INT1)
  Serial.println("RFID Readers");
  // binds the ISR functions to the falling edge of INTO and INT1
  attachInterrupt(2, ISR_INT0, FALLING);
  attachInterrupt(3, ISR_INT1, FALLING);
  // This waits to make sure that there have been no more data pulses before processing data
  if (!flagDone) {
    if (--weigand_counter == 0)
      flagDone = 1;
  // if we have bits and we the weigand counter went out
  if (bitCount > 0 && flagDone) {
    unsigned char i;
    Serial.print("Read ");
    Serial.print(bitCount);
    Serial.print(" bits. ");
    // we will decode the bits differently depending on how many bits we have
    // see www.pagemac.com/azure/data_formats.php for mor info
    if (bitCount == 34)
      // 35 bit HID Corporate 1000 format
      // facility code = bits 2 to 14
      for (i=2; i<14; i++)
         facilityCode <<=1;
         facilityCode |= databits[i];
      // card code = bits 15 to 34
      for (i=14; i<33; i++)
         cardCode <<=1;
         cardCode |= databits[i];
      printBits();
    else if (bitCount == 26)
      // standard 26 bit format
      // facility code = bits 2 to 9
      for (i=1; i<9; i++)
         facilityCode <<=1;
      // card code = bits 10 to 23
      for (i=9; i<25; i++)
         cardCode <<=1;
      printBits();
    else {
      // you can add other formats if you want!
     Serial.println("Unable to decode.");
     // cleanup and get ready for the next card
     bitCount = 0;
     facilityCode = 0;
     cardCode = 0;
     for (i=0; i<MAX_BITS; i++)
       databits[i] = 0;
void printBits()
      // I really hope you can figure out what this function does
      Serial.print("FC = ");
      Serial.print(facilityCode);
      Serial.print(", CC = ");
      Serial.println(cardCode);
However, when I try to use it, the program decides to randomly stop. Sometimes the serial monitor only sees "RFID RE" or such iteration from the print line in startup, sometimes it gets to the loop and loops but it too eventually just...stops... It works fine while the loop is running but just stops. I've wired it up correctly on my mega (I think):
RED- 12v PSU
BLACK- Ground from 12v PSU
GREEN-Digital Pin 2
White-Digital pin 3
Grey-Not wired (says to be for the beeper)
Purple-Ground(Not sure what this wire is for, I thought it might be so that the device has a common ground with the arduino).
Any help would be greatly appreciated!
Try using a stronger external pull up resistor on the weigand inputs, like 4K7.
This function takes interrupt numbers (0 & 1) not pin numbers (2 & 3). For portability there is a function to do the translation:
  attachInterrupt(digitalPinToInterrupt(2), ISR_INT0, FALLING);
  attachInterrupt(digitalPinToInterrupt(3), ISR_INT1, FALLING);
