Trying to use blink without delay + easydriver
Hi There,
I'm trying to modify the blink without delay sketch to run my stepper motor. I'm using the easydriver board and it works fine with I have a simple loop that uses the (delay) function.
Now I'm trying to do the same but without using the delay function. I figured the code below would work. The motor does move a bit but it seems phasey. Can anyone see why this wouldn't work? The LED doesn't miss a beat. But the motor is not behaving.
/* Blink without Delay
 * Turns on and off a light emitting diode(LED) connected to a digital
 * pin, without using the delay() function.  This means that other code
 * can run at the same time without being interrupted by the LED code.
 * http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
int dirpin = 3;
int steppin = 5;
int ledPin = 13;                // LED connected to digital pin 13
int value = LOW;                // previous value of the LED
long previousMillis = 0;        // will store last time LED was updated
long interval = 100;           // interval at which to blink (milliseconds)
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  pinMode(dirpin, OUTPUT);
  pinMode(steppin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, is the difference
  // between the current time and last time we blinked the LED bigger than
  // the interval at which we want to blink the LED.
  if (millis() - previousMillis > interval) {
    previousMillis = millis();   // remember the last time we blinked the LED
    // if the LED is off turn it on and vice-versa.
    if (value == LOW)
      value = HIGH;
      value = LOW;
    digitalWrite(ledPin, value);
    digitalWrite(steppin, value);
Thanks in Advance.
