Trying to use button holds to change states
Here is the code, with some extra stuff because I was just trying to experiment with buttons:
/* This is an example sketch provided to test the application of dual button commands
 as well as the application of a requirement for the user to hold down certain button(s)
 for a specific amount of time. */
int programmingHold = 2000;
unsigned long startHoldTime;
unsigned long time = millis();
int buttonOne = 11;
int buttonTwo = 12;
  pinMode(buttonOne, INPUT);
  pinMode(buttonTwo, INPUT);
  pinMode(13, OUTPUT);
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH);
  pinMode(3, OUTPUT);
  digitalWrite(3, HIGH);
  int button = digitalRead(buttonOne);
  Serial.print(button);
  Serial.print(" | ");
  Serial.print(time);
  Serial.print(startHoldTime);
  Serial.print(time - startHoldTime);
  delay(2);
  if (button)
    startHoldTime = time;
    if (button && ((time - startHoldTime) >= programmingHold))
      digitalWrite(13, HIGH);
  else if (button == LOW)
    if ((button == LOW) && ((time - startHoldTime) >= programmingHold))
      digitalWrite(13, LOW);
The idea being that if you connect power (in this case I'm just using a jumper to connect pin 2 to pin 11, but the idea would be to use a button) for 2 seconds, it will turn the LED on pin 13 on, and if you remove power for more than 2 seconds, the LED will then shut off. The code is not working at all, currently, but even when I remove the timing aspects, as seen below, my serial monitor shows that pin 11 is reading as HIGH for several seconds after I remove power.
int buttonOne = 11;
int buttonTwo = 12;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  Serial.print(time);
  delay(2);
  if (button == HIGH)
I'm very confused as to why the pin seems to still be getting power several seconds after I remove all connection from it. It has to be something I'm missing, but I'm just having a hard time understanding what is going on.
Hassurunous:
I don't think there is any point in trying to capture time = millis() BEFORE setup()
I suggest you move that line to the bottom of setup().
But I doubt if that is the real problem.
You need a variable to record whether the led is on (say) ledState = 0
this pseudo code explains the process
IF ledState == 0
       You need to capture time when the button is  pressed AND when it is released
        AND you need to check whether your 2 secs has expired
               it will reset if the button is released
         IF the button is down and the time expires
          CHANGE the variable to ledState = 1
almost the same process is required to turn the led off
IF ledState == 1
            use a different variable for the time so it can't be mixed up with the other part
               it will reset if the button is pressed
         IF the button is UP and the time expires
          CHANGE the variable to ledState = 0
and after all that you just have
digitalWrite(ledPin, ledState);
The usual way to manage the time is like this
when button changes
ledOnMillis = millis()
and to see if the time has passed
if (millis() - ledOnMills >= ledOnWaitInterval) {
...R
Why not just toggle the LED? That way the previous state is irrelevant.
Using Direct Port manipulation:
LED, pin 13 (Uno)
void setup(){
void loop(){
//This function toggles pin 13
PORTB = PORTB ^ (1<<PORTB5);  // toggle bit 5, leave others untouched
Pin mapping:
Why are you using pin 2 to supply pin 11 with 5V when the 5V output will do the same and leave pin 2 free for other things?
