Right now a 3.3V digital HIGH on pin 3 of an Arduino Pro Mini is not working.
Thanks for any advice!
CoffeePress.ino (2.63 KB)
On what grounds do you base this observation?
BYJ48 Stepper motor code
Connect :
IN1 >> D8
IN2 >> D9
IN3 >> D10
IN4 >> D11
VCC ... 5V Prefer to use external 5V Source
Gnd
written By :Mohannad Rawashdeh
http://www.instructables.com/member/Mohannad+Rawashdeh/
28/9/2013
And LED interrupt based on https://www.arduino.cc/en/Reference/AttachInterrupt
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
int Steps = 0;
boolean Direction = true;// gre
unsigned long last_time;
unsigned long currentMillis ;
int steps_left=4095;
long time;
const byte pressButton;
const byte IOTpressed = 3;
volatile byte state = LOW;
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(IOTpressed, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(IOTpressed), onOff, RISING);
digitalWrite(pressButton, state);
if (pressButton==HIGH) {
while(steps_left>0){
currentMillis = micros();
if(currentMillis-last_time>=1000){
press(1);
time=time+micros()-last_time;
last_time=micros();
steps_left--;
Direction=!Direction;
steps_left=4095;
state = !state;
void onOff() {
state = !state;
void press(int xw){
for (int x=0;x<xw;x++){
switch(Steps){
case 0:
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
case 1:
digitalWrite(IN3, HIGH);
case 2:
digitalWrite(IN4, LOW);
case 3:
digitalWrite(IN2, HIGH);
case 4:
case 5:
digitalWrite(IN1, HIGH);
case 6:
case 7:
default:
SetDirection();
void SetDirection(){
if(Direction==1){ Steps++;}
if(Direction==0){ Steps--; }
if(Steps>7){Steps=0;}
if(Steps<0){Steps=7; }
AWOL:
Clever!
I connected Vcc of the Arduino to pin 3, while Ground and Pin 10 were on my tongue.
I felt no tingling.
What makes you think zero will ever equal one?
void onOff() {
state = !state;
Looks like a logic error to me.
const byte pressButton; << results in pressButton = 0
digitalWrite(pressButton, state); << writes a 0 or 1 to pin D0
if (pressButton==HIGH) { << nothing ever makes pressButton HIGH, so this is always false
Did you make the code corrections pointed-out?
CrossRoads:
Looks like a logic error to me.const byte pressButton; << results in pressButton = 0
The Interrupt pin calls
void onOff()
and that changes state which
BTW awesome link for BB codes http://www.dailywritingtips.com/forum/misc.php?do=bbcode
Still having to wait 5 minutes between posts. "You have exceeded the number of posts you can make in a 5 minutes period. Please try again later."
Have you fixed the problem pointed-out in replies #3 and #5?
(The five minute pause is to discourage drive-by spammings. It doesn't seem so long if you use the time to review your code and the replies people have posted)
