I'm getting the following error while trying to upload the Blink code -->
Below is the Error :
Sketch uses 80265 bytes (0%) of program storage space. Maximum is 10000000 bytes.
"C:\Users\Sumith Raj Shetty\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin/bash.exe" "--verbose" "--noprofile" "C:\Users\Sumith Raj Shetty\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh" "C:\Users\Sumith Raj Shetty\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin" "C:\Users\Sumith Raj Shetty\AppData\Local\Temp\arduino\sketches\3738505C1C8620006BC13CCD666A98D5/sketch_dec1a.ino.elf" "COM8"
cygwin warning:
MS-DOS style path detected: C:\Users\Sumith Raj Shetty\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadGalileo_win.sh
Preferred POSIX equivalent is: /cygdrive/c/Users/Sumith Raj Shetty/AppData/Local/Arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0/clupload/cluploadGalileo_win.sh
CYGWIN environment variable option "nodosfilewarning" turns off this warning.
Consult the user's guide for more details about POSIX paths:
http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
starting download script
Args to shell: C:\Users\Sumith Raj Shetty\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Sumith Raj Shetty\AppData\Local\Temp\arduino\sketches\3738505C1C8620006BC13CCD666A98D5/sketch_dec1a.ino.elf COM8
COM PORT 8
Converted COM Port COM8 to tty port /dev/ttyS7
Sending Command String to move to download if not already in download mode
Deleting existing sketch on target
#!/bin/sh
clupload script to invoke lsz
Copyright (C) 2014 Intel Corporation
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
ARG 1: Path to lsz executable.
ARG 2: Elf File to download
ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
Transfer incomplete
Execute the target download command
Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
Moving downloaded file to /sketch/sketch.elf on target
lsz: cannot open C:\Users\Sumith: No such file or directory
lsz: cannot open Raj: No such file or directory
lsz: cannot open Shetty\AppData\Local\Temp\arduino\sketches\3738505C1C8620006BC13CCD666A98D5/sketch_dec1a.ino.elf: No such file or directory
Can't open any requested files.
Transfer incomplete
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
Retry 0: Got TIMEOUT
Transfer incomplete
If anyone is aware how to proceed further please help. Thank you.
