I wanted to impliment a joystick instead of the normal wasd movement to my arduino bluetooth conrolled car that has a HC SR04 sensor. The joystick by itself works perfectly but whenever i try to implement the code for the sensor, my joystick inputs take 20 to 30 seconds to register, if they even register. Does anyone know if this is possible to implement and how to do so.
int dataIn[5] {0,0,0,0};
int in_byte = 0;
int array_index = 0;
int TRIGGER=3;
int echo=4;
int last;
long duration;
int distance;
unsigned long previousMicros=0;
#define in1 10
#define in2 11
#define in3 12
#define in4 13
Serial.begin (9600);
pinMode (TRIGGER,OUTPUT);
pinMode (echo, INPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
unsigned long currentMicros = micros();
digitalWrite(TRIGGER,LOW);
if (currentMicros - previousMicros > 4){
digitalWrite (TRIGGER,HIGH);
previousMicros = currentMicros;
if (currentMicros - previousMicros > 12){
digitalWrite (TRIGGER,LOW);
duration= pulseIn(echo,HIGH);
distance=duration / 58;
int trenutno = distance;
Serial.println(last);
if (trenutno!=0)
last=trenutno;
if (last<20 && digitalRead(in1)==HIGH && digitalRead(in2)==LOW &&digitalRead(in3)==HIGH &&digitalRead(in4)==LOW){
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
if (Serial.available() > 0) {
in_byte = Serial.read();
if (in_byte == (255)) {
array_index = 0;
dataIn[array_index] = in_byte;
array_index = array_index +1;
//print the array
Serial.print (", X:");
Serial.print (dataIn[2]);
Serial.print (", Y:");
Serial.print (dataIn[3]);
Serial.println (",");
int x = dataIn[2];
int y = dataIn[3];
if (x==100 && y==100){ //stoji
else if (y>=0 && y<=50 && x>=50 && x<=150 && last>20){
digitalWrite(in1, HIGH);
digitalWrite(in3, HIGH);
else if (y>=200 && y<=250 && x>=50 && x<=150) {
digitalWrite(in2, HIGH);
digitalWrite(in4, HIGH);
else if (y>=50 && y<=150 && x>=200 && x<=250) {
else if (y>50 && y<=150 && x>=0 && x<=50){
else if (y>0 && y<=50 && x>=200 && x<=250){
else if (y>0 && y<=50 && x>=0 && x<=50){
else if (y>200 && y<=250 && x>=200 && x<=250){
else if (y>200 && y<=250 && x>=0 && x<=50){
