trying to use long values
Hi! I'm trying to make a stepper turning a long time, with a IR remote.
I try to modify a simple code I found, mutliplying the steps (I'm still not sure of the turn numbers I will need).
It creates too big values, so I mess with long and L but I just can't get it to work...
Could somebody suggests me whats wrong?
      case 0xFFA857: // VOL+ button pressed
                      small_stepper.setSpeed(500); //Max seems to be 500
                      Steps2Take =  2048L*100L;  // Rotate CW
                      small_stepper.step(Steps2Take) long ;
                      delay(2000);
Your code, being incomplete, doesn't compile.
That doesn't look like valid syntax to me.
Sorry, yes I didn't put the rest of the code, it thought it was not necessary to find the error
here's the errors I get
34: warning: overflow in implicit constant conversion [-Woverflow]
error: expected ';' before 'long'
#include "Stepper.h"
#include "IRremote.h"
/*----- Variables, Pins -----*/
#define STEPS  32   // Number of steps per revolution of Internal shaft
int  Steps2Take;  // 2048 = 1 Revolution
int receiver = 12; // Signal Pin of IR receiver to Arduino Digital Pin 6
/*-----( Declare objects )-----*/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 10, 9, 11);
IRrecv irrecv(receiver);    // create instance of 'irrecv'
decode_results results;     // create instance of 'decode_results'
  irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) // have we received an IR signal?
    switch(results.value)
                      delay(2000);
      case 0xFF629D: // VOL- button pressed
                      Steps2Take   =  -2048;  // Rotate CCW close
                      small_stepper.step(Steps2Take);
                      delay(2000);
      irrecv.resume(); // receive the next value
                 digitalWrite(8, LOW);
                 digitalWrite(9, LOW);
                 digitalWrite(10, LOW);
                 digitalWrite(11, LOW);
}/* --end main loop -- */
williamslg:
16bit variable:
int  Steps2Take;
compiler is your friend!
looks like still something out of place there, no?
