Trying to use LVGL ERROR
It is the CPU on your computer that is performing the compilation, not the processor on the GIGA R1 WiFi. The processor on the GIGA R1 WiFi only runs the compiled binary that is produced by the compiler running your your computer's CPU.
Thanks, of course. Is there any way to reuse the compiled code?
Arduino IDE does cache the compiled core and libraries. These are reused on subsequent compilations until such time as that cache is invalidated due to a change in the source code (as occurs when you update the "Arduino Mbed OS Giga Boards " platform or the "lvgl" library, or if you manually modified the code in the core or library).
If you enable the "Show verbose output during: ☐ compilation" option in the Arduino IDE preferences, you can actually see which cached objects are being used vs. compiled from source.
For example:
Compiling libraries...
Compiling library "Arduino_H7_Video"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\video_modes.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\edid.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\dsi.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\anx7625.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\st7701.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\H7DisplayShield.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\Arduino_H7_Video.cpp.o
Compiling library "lvgl"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_label.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_class.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_draw.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_scroll.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_event.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_group.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\display\lv_display.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_style_gen.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_buf.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_property.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_arc.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_draw_buf_pxp.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_image.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_draw_pxp_fill.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_draw_pxp.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_refr.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_draw_pxp_img.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_draw_pxp_layer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_pxp_cfg.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_pxp_osa.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_id_builtin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\lv_pxp_utils.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_pos.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_arc.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_fill.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_border.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_img.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_buf_vglite.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_label.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_layer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_vglite_buf.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_draw_vglite_triangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_vglite_path.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_style.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\lv_obj_tree.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_vglite_matrix.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\lv_vglite_utils.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_border.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_arc.c.o
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -x assembler-with-cpp -mcpu=cortex-m7 -mfpu=fpv5-d16 -DARDUINO=10607 -DARDUINO_GIGA -DARDUINO_ARCH_MBED_GIGA -DARDUINO_ARCH_MBED "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\variants\\GIGA" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\Arduino_H7_Video\\src" "-Ic:\\Users\\per\\Documents\\Arduino\\libraries\\lvgl\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\Portenta_SDRAM\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\ea_malloc" -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino/api/deprecated" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino" "@C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\variants\\GIGA/../GIGA/includes.txt" "c:\\Users\\per\\Documents\\Arduino\\libraries\\lvgl\\src\\draw\\sw\\blend\\helium\\lv_blend_helium.S" -o "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\helium\\lv_blend_helium.S.o"
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -x assembler-with-cpp -mcpu=cortex-m7 -mfpu=fpv5-d16 -DARDUINO=10607 -DARDUINO_GIGA -DARDUINO_ARCH_MBED_GIGA -DARDUINO_ARCH_MBED "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\variants\\GIGA" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\Arduino_H7_Video\\src" "-Ic:\\Users\\per\\Documents\\Arduino\\libraries\\lvgl\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\Portenta_SDRAM\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\libraries\\ea_malloc" -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino/api/deprecated" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino/api/deprecated-avr-comp" "-iprefixC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\cores\\arduino" "@C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\variants\\GIGA/../GIGA/includes.txt" "c:\\Users\\per\\Documents\\Arduino\\libraries\\lvgl\\src\\draw\\sw\\blend\\neon\\lv_blend_neon.S" -o "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\neon\\lv_blend_neon.S.o"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_mask.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_mask_rectangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_label.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_utils.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_triangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_vector.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_triangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_image.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_draw_rect.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\lv_draw_dave2d_fill.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\lv_image_decoder.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sdl\lv_draw_sdl.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\blend\lv_draw_sw_blend.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_buf_vg_lite.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_arc.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_gradient.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\blend\lv_draw_sw_blend_to_rgb565.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_arc.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_border.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\blend\lv_draw_sw_blend_to_argb8888.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_box_shadow.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\blend\lv_draw_sw_blend_to_rgb888.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_fill.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_fill.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_border.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_img.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_layer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_mask_rect.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_letter.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_vector.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_triangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_box_shadow.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_math.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_mask_rect.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_img.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_vector.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_decoder.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\evdev\lv_evdev.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\libinput\lv_libinput.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\libinput\lv_xkb.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_triangle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\fb\lv_linux_fbdev.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_transform.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\drm\lv_linux_drm.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\lv_draw_sw_mask.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\ili9341\lv_ili9341.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\tft_espi\lv_tft_espi.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7735\lv_st7735.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\lcd\lv_lcd_generic_mipi.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7789\lv_st7789.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7796\lv_st7796.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_touchscreen.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_fbdev.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_entry.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_lcd.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\sdl\lv_sdl_mouse.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\sdl\lv_sdl_keyboard.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\windows\lv_windows_display.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\sdl\lv_sdl_mousewheel.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\windows\lv_windows_context.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\sdl\lv_sdl_window.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\windows\lv_windows_input.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\x11\lv_x11_display.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\x11\lv_x11_input.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_fmt_txt.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_draw_vg_lite_label.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_grad.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_pending.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_utils.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_cache.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\lv_vg_lite_path.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_image_cache.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_libuv.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\lv_nuttx_profiler.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_dejavu_16_persian_hebrew.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_binfont_loader.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_12.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_16.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_10.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_18.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_20.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_14.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_22.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_28_compressed.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_28.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_26.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_30.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_34.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_24.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_32.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_36.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_38.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\indev\lv_indev.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\indev\lv_indev_scroll.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\bin_decoder\lv_bin_decoder.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\lv_freetype.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\flex\lv_flex.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_40.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\lv_layout.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\grid\lv_grid.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_42.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_cbfs.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_44.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\ffmpeg\lv_ffmpeg.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_46.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_8.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_montserrat_48.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_unscii_16.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_simsun_16_cjk.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\gif\gifdec.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\lv_font_unscii_8.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\lz4\lz4.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\qrcode\qrcodegen.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\barcode\lv_barcode.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\rle\lv_rle.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\barcode\code128.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\bmp\lv_bmp.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgAnimation.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgBezier.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgCanvas.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgCapi.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgCompressor.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgFill.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgInitializer.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgLoader.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgMath.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgPaint.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgPicture.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgRawLoader.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgRender.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSaver.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgScene.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgShape.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgStr.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSvgCssStyle.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSvgLoader.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSvgPath.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSvgSceneBuilder.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSvgUtil.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwCanvas.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\lv_ftsystem.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwFill.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwImage.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwMath.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwMemPool.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwRaster.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwRenderer.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\lv_freetype_image.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwShape.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_memfs.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_fatfs.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\lv_freetype_outline.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwStroke.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgSwRle.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\lv_freetype_glyph.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgTaskScheduler.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\tvgXmlParser.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\tjpgd\tjpgd.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_littlefs.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_win32.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_stdio.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\lv_fs_posix.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\cache\_lv_cache_lru_rb.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\cache\lv_cache.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_anim_timeline.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\cache\lv_cache_entry.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_array.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_async.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_color.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_color_op.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_ll.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_log.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\lodepng\lodepng.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_lru.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_bidi.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_palette.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\libpng\lv_libpng.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_templ.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_rb.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\libjpeg_turbo\lv_libjpeg_turbo.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\gif\lv_gif.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_cmsis_rtos2.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_utils.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\cache\lv_image_cache.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_anim.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_freertos.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_style_gen.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_pthread.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_rtthread.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_os_none.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_area.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\qrcode\lv_qrcode.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\lodepng\lv_lodepng.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\lv_windows.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_event.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_text.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_fs.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_text_ap.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_math.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\vg_lite_tvg\vg_lite_matrix.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\vg_lite_tvg\vg_lite_tvg.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\monkey\lv_monkey.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\rlottie\lv_rlottie.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_style.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\builtin\lv_sprintf_builtin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\clib\lv_sprintf_clib.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_timer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\builtin\lv_string_builtin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\clib\lv_mem_core_clib.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\clib\lv_string_clib.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\builtin\lv_tlsf.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\rtthread\lv_sprintf_rtthread.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\micropython\lv_mem_core_micropython.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\rtthread\lv_mem_core_rtthread.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\rtthread\lv_string_rtthread.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\file_explorer\lv_file_explorer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\fragment\lv_fragment_manager.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\fragment\lv_fragment.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\gridnav\lv_gridnav.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\ime\lv_ime_pinyin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\snapshot\lv_snapshot.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\sysmon\lv_sysmon.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\builtin\lv_mem_core_builtin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\lv_mem.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\tiny_ttf\lv_tiny_ttf.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\tjpgd\lv_tjpgd.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\tick\lv_tick.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\arc\lv_arc.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\animimage\lv_animimage.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\button\lv_button.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\lv_init.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\bar\lv_bar.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\buttonmatrix\lv_buttonmatrix.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\lv_profiler_builtin.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\calendar\lv_calendar_header_arrow.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\calendar\lv_calendar_header_dropdown.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\chart\lv_chart.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\checkbox\lv_checkbox.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\objx_templ\lv_objx_templ.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\canvas\lv_canvas.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\image\lv_image.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\imagebutton\lv_imagebutton.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\dropdown\lv_dropdown.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\keyboard\lv_keyboard.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\label\lv_label.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\led\lv_led.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\line\lv_line.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\list\lv_list.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\imgfont\lv_imgfont.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\menu\lv_menu.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\observer\lv_observer.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\roller\lv_roller.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\msgbox\lv_msgbox.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\scale\lv_scale.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\span\lv_span.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\spinbox\lv_spinbox.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\mono\lv_theme_mono.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\slider\lv_slider.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\simple\lv_theme_simple.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\switch\lv_switch.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\calendar\lv_calendar.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\default\lv_theme_default.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\tileview\lv_tileview.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\lv_theme.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\textarea\lv_textarea.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\table\lv_table.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\spinner\lv_spinner.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\win\lv_win.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\tabview\lv_tabview.c.o
Compiling library "Portenta_SDRAM"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Portenta_SDRAM\ram_internal.c.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Portenta_SDRAM\SDRAM.cpp.o
Compiling library "ea_malloc"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\ea_malloc\malloc_freelist.c.o
Compiling core...
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\core\variant.cpp.o
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\core\pure_analog_pins.cpp.o
Using precompiled core: C:\Users\per\AppData\Local\Temp\arduino\cores\arduino_mbed_giga_giga_split_100_0,target_core_cm7_1e422b06194ebb4a9be342df1cb789c8\core.a
Linking everything together...
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -E -P -x c -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 "C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_giga\\4.1.3\\variants\\GIGA/linker_script.ld" -o "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309/linker_script.ld"
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\sketch\\objs.a" "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\sketch\\sketch_may3a.ino.cpp.o"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Arduino_H7_Video\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\core\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\display\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\pxp\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\nxp\vglite\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\renesas\dave2d\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sdl\objs.a
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\helium\\objs.a" "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\helium\\lv_blend_helium.S.o"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\blend\objs.a
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\neon\\objs.a" "C:\\Users\\per\\AppData\\Local\\Temp\\arduino\\sketches\\6D88D5BC8EEDB25A2DBCF932A14F4309\\libraries\\lvgl\\draw\\sw\\blend\\neon\\lv_blend_neon.S.o"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\sw\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\draw\vg_lite\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\drm\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\fb\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\ili9341\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\lcd\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7735\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7789\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\st7796\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\display\tft_espi\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\evdev\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\libinput\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\nuttx\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\sdl\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\windows\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\drivers\x11\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\font\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\indev\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\flex\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\grid\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\layouts\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\barcode\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\bin_decoder\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\bmp\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\ffmpeg\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\freetype\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\fsdrv\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\gif\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\libjpeg_turbo\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\libpng\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\lodepng\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\lz4\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\qrcode\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\rle\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\rlottie\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\thorvg\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\tiny_ttf\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\libs\tjpgd\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\cache\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\misc\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\osal\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\file_explorer\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\fragment\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\gridnav\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\ime\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\imgfont\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\monkey\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\observer\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\snapshot\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\sysmon\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\others\vg_lite_tvg\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\builtin\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\clib\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\micropython\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\stdlib\rtthread\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\default\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\mono\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\themes\simple\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\tick\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\animimage\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\arc\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\bar\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\button\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\buttonmatrix\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\calendar\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\canvas\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\chart\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\checkbox\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\dropdown\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\image\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\imagebutton\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\keyboard\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\label\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\led\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\line\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\list\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\menu\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\msgbox\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\objx_templ\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\roller\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\scale\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\slider\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\span\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\spinbox\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\spinner\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\switch\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\table\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\tabview\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\textarea\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\tileview\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\lvgl\widgets\win\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\Portenta_SDRAM\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\libraries\ea_malloc\objs.a
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino\sketches\6D88D5BC8EEDB25A2DBCF932A14F4309\core\objs.a
Thank you, the number of lines in the compile code is amazing.
Haha, yeah you can see why it takes so long! Even with a very simply sketch code, there is a lot going on under the hood in these libraries and the core that still must be handled (even when it is precompiled it still takes some additional handling). Even if each process only lasts a fraction of a second, there are so many of them it can still really add up.
