Trying to use Motor Shield and XC4382 Bluetooth module together
Hi guys
I’m trying to use the XC4382 Bluetooth 4 LE module with the Adafruit motor shield v1. According to the motor shield docs, digital pins 2 and 13 are unused, so that’s what I’m trying to use to hook up the Bluetooth module. Problem is, I don’t see any serial activity from the Bluetooth module (just the blinking red light meaning it’s ready to pair).
I have pin 2 connected to the RX pin on the Bluetooth module via a voltage splitter to reduce +ve to 3.3v, and pin 13 connected to TX pin, and +5v and GND connected to the power pins.
Thanks for any help.
Sketch code:
#include <SoftwareSerial.h>
#define rxPin 13
#define txPin 2
SoftwareSerial BTSerial(rxPin, txPin);
//#include <AltSoftSerial.h>
//AltSoftSerial BTSerial(0,1);
char c=' ';
boolean NL = true;
    pinMode(rxPin, INPUT);
    pinMode(txPin, OUTPUT);
    Serial.print("Sketch:   ");   Serial.println(__FILE__);
    Serial.print("Uploaded: ");   Serial.println(__DATE__);
    Serial.println(" ");
    BTSerial.begin(9600);
    Serial.println("BTserial started at 9600");
    Serial.println("");
    // Read from the Bluetooth module and send to the Arduino Serial Monitor
    if (BTSerial.available())
        c = BTSerial.read();
        Serial.write(c);
    // Read from the Serial Monitor and send to the Bluetooth module
    if (Serial.available())
        c = Serial.read();
        BTSerial.write(c);
        // Echo the user input to the main window. The ">" character indicates the user entered text.
        if (NL) { Serial.print(">");  NL = false; }
        Serial.write(c);
        if (c==10) { NL = true; }
I just happened to have a HC05 bluetooth module connected to my Uno. I loaded your sketch, changed the pins for RX and TX to my setup and ran your code. Whatever I type into the serial monitor is echoed back by to HC05 and I see what I typed on my tablet (running a Bluetooth terminal). So the code works, with HC05, the problem is elsewhere.
Can you show how this is connected? What are the resistor values? Can you include the Bluetooth module data sheet?
