I'm using a sound sensor with an Arduino Uno. I'm trying to have once the sound sensor reads past a level 9 to turn the pin high. Also as a way to check it I'm trying to get it to print "The pin is high."
It's showing me the numeric value of the Analog read, and that I'm going past level 9. But it does not show "The line is high."
Any help is appreciated.
pinMode(4, OUTPUT); //setup pin 4 as output
pinMode(A0, INPUT); // setup input
Serial.begin(9600); // setup serial
if(analogRead(A0) > 9) { //if the analog value of A0 is greater than 9 then
digitalWrite(4, HIGH); //write digital pin 4 high
else {
digitalWrite(4, LOW); //if it isn't higher than 9, make pin 4 low
Serial.println(analogRead(A0));
delay(100);
if (4 == HIGH)
Serial.println("The pin went high");
delay(100);
So, if the number 4 is ever exactly equal to the value defined by HIGH (which it won't be), execute the Serial.println because there are no curly brackets so the if statement continues to the semicolon. Probably NOT what you intended.
Thank you for the help. I think I fixed the first part of what you are saying by defining int - please see below. Thanks again.
int LedOutput = 6;
int SoundSensor = A0;
pinMode(LedOutput, OUTPUT); //make sure you have set your pins as inputs or outputs
pinMode(SoundSensor, INPUT); // setup input
if(analogRead(SoundSensor) > 9) { //if the analog value of SoundSensor/Input A0 is greater than 9 then
digitalWrite(LedOutput, HIGH); //write digital pin LedOutput high
else {
digitalWrite(LedOutput, LOW); //if it isn't higher than 9, make pin LedOutput low
delay(100);
if (digitalRead(LedOutput) == HIGH){
Serial.println("The line went high");
Instead of reading the analog input each time you need it, read it at the top of your void loop(), save it to a variable and then use that variable for comparisons and printouts through the rest of your loop.
YOU DID IT!! All I had to do was move the Serial Println to the top of the void loop and it worked!!!!! I think it was also incorrectly placed in if bracket and interfering. THANK YOU!
