Trying to use TIMER0_OVF_vect on attiny85
Greetings,
I am trying to port some example code I found at:
http://wiki.openmusiclabs.com/wiki/PWMDAC
to the ATtiny85.
I'm using the procedure described at:
http://hlt.media.mit.edu/?p=1695
to program my attiny85 chip.
The trick is that the example code uses the TIMER1_CAPT_vect to trigger the ADC (on the arduino). This isn't available on the '85. So instead, I'd like to use TIMER0_OVF_vect.
Compiling my code gets me an error:
core.a(wiring.c.o): In function init': /home/peter/opt/arduino-1.0.5/hardware/arduino/cores/arduino/wiring.c:193: multiple definition of __vector_5'
adc2pwm_attiny85.cpp.o:/home/peter/opt/arduino-1.0.5/adc2pwm_attiny85.ino:44: first defined here
which I expect is because the arduino core uses TIMER0_OVF_vect for its own time-related functions.
What I am wondering is, since I'm not using any of the time-related functions in my code, is there a nice way (i.e. something limited to the code in my sketch) to disable the time-related functions and thereby free up the TIMER0_OVF_vect?
Thanks,
Peter.
You are correct. TIMER0_OVF_vect is defined in your core for the interrupt used by millis().
If you define it again you get multiple definitions, followed by a linker error.
If you really need that interrupt I believe there's cores that use timer 1 for millis(), also options in the source code for your core to choose a timer. Dig around.
This core use Timer1 for millis() for Attiny85t:
https://code.google.com/p/arduino-tiny/
My core for the Attiny85 didn't give that error, not sure where I got it.
However compiling for the Uno, I get it, but this doesn't:
ISR (TIMER0_OVF_vect)
  // whatever
int main ()
    // your code here
By using main rather than setup and loop, the code that users Timer 0 is not linked, and so there is no clash. You could do something similar. Of course you have to do your own hardware initialization, and you won't have millis(), delay() etc.
