I want to see all the elements of my array on my serial monitor without having to use the slide bar. wrapping is what i want.
i've googled it and everybody seems to want to talk about strings, which seems easier to deal with.
is there a way i can set a wrap length for serial.print an array ?
pratto:
Yes, but you have to do it when you are printing. Without see your code, after some number of Serial.print, make one of them a Serial.println.
it works beautifully. i just wish i had figured it out. but not knowing about tab or %= was a bit of a stumbling block. but i was up to speed on random number generation.
I went through it and understand it, except for a few things.
why use bytes as the array type, as opposed to int ?
what is the purpose of this statement 'while (!Serial);' ?
why is there a number at the very top left, above the first column ?
pratto:
It's just an illustration. Any variable type could be used. As long as you've got RAM to put it in along with any other variables the sketch might need.
pratto:
pratto:
Be the processor. Step through printArray() one line at a time and analyze what each statement does. Use pencil and paper to keep track of changing variables if need be. Arduino Reference - Arduino Reference
I had figured out that the upper left number was an array element that wasn't properly evaluated by the
((x % columns) == 0), zero being the problem. and was flopping around trying to figure out the fix. i had ruled out if x=0 x=x+1;
but i put the revised code in and it is still a problem child. in your example the first row has 11 columns.
i'll keep working on it.
i don't know if this makes any sense, but if i take 1 extra sensor reading, and eliminate the first, it works fine columnwise.
byte anArray[289];
while (!Serial);
randomSeed(analogRead(A6));
for (int x = 0; x < 289; x++)
anArray[x] = random(256);
printArray();
void printArray()
byte columns = 10;
for (int x = 1; x < 289; x++)
Serial.print(anArray[x]);
Serial.print("\t");
if ((x % columns) == 0)
as you can see, i start at x = 1. this eliminates the column number vs. array number problem.
i am tired now, but it seems like it doesn't matter if i take an extra reading, or lose one. i am taking hundreds and they don't have to start at a certain time.
i can see that for some applications this approach wouldn't work.
