Trying to write a delay function based on Blink Without Delay
Here's my attempt. I'm having to call the changeMotorState() function within the new delay function, which is undesirable. I want a simple delay function based on millis.
// constants won't change. Used here to set a pin number :
const int motorPin =  13;      // the number of the motor pin
// Variables will change :
int motorState = LOW;             // motorState used to set the motor
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time motorState was updated
  // set the digital pin as output:
  pinMode(motorPin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // if the motor is off turn it on and vice-versa:
  waitNoDelay(5000);
  // set the motor with the motorState of the variable:
  digitalWrite(motorPin, motorState);
void waitNoDelay(const long interval) {
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the motor
    cahngeMotorState();
void cahngeMotorState() {
  if (motorState == LOW) {
    motorState = HIGH;
    motorState = LOW;
However, I want control over how long I can keep the LED on or off. For example, LOW for 30s, then HIGH for 15s, then LOW for 300s.
That means that you did NOT understand the concept of doing things at timed intervals without using delay().
You do not have to use a constant for the interval. You do not have to use the same value for interval every time.
Your waitNoDelay() function has a silly name, since it doesn't cause any waiting. Change is misspelled in the name of the function that it calls.
You could use such a construct to control your LED (untested):
unsigned long cycleStartMillis ;
void setup(){
  cycleStartMillis = millis() ;
  if ( millis() - cycleStartMillis < 30 ) {
     // switch led off
  else if ( millis() - cycleStartMillis < 45 ) {
     // switch led on
  else if ( millis() - cycleStartMillis < 345 ) {
     // switch led off
  else {
The elapsedMillis.h library does this very well.
