So I cannot get the Tscinbuny app to connect to the car via wifi. The app is refusing to connect. Tscinbuny customer service have been less than helpful. How can I trouble shoot this before just offloading it into the bin. I have my network setup to 2.4 G.
WiFi connected
Starting web server on port: '80'Starting stream server on port: '81'Camera Ready! Use 'http://192.168.xx.xx' to connect
Any help troubleshooting will be greatly appreciated.
JG
Your topic does not indicate a problem with IDE 1.x and hence has been moved to a more suitable location on the forum.
Where do you see that? Serial monitor?
Assuming the car runs the web server, did you check the web server's IP address in your router and use that instead of http://192.168.xx.xx in the app.
I don't think that I can help further, no experience with your products.
A similar problem. When moving to the address in the browser, long loading the page. TSCINBUNY in the application is also unsuccessful.
I tried to solve the problem through AI, nothing happened.
Hello all,
The solution is to install the older version of esp32 board to Arduino IDE. The toy works perfectly with version 1.0.6. Detailed reason of incompatibility with 3.2.0 current version is unknown yet...
Buttons text in Russian, but it isn't a problem....
Translate to any language as you wish
Annotation from repository
"Removed garbage and artifacts from the code.
Upgrade to the latest version of the ESP32 framework (v.3.2.0)
Russified control buttons
Added a button to return the front module to the middle position.
Optimized camera settings (OV2640 module)
