Hi all,I have project using TSD305 infrared sensor. I'm using this (GitHub - TEConnectivity/TSD305_Arduino_Library: Arduino library for the TSD305 sensor) library at the moment.
Unfortunately the data I am getting seem not correct and temperature of object and sensor always the same. So I decided to cross check with data sheet to see if there is the I am using the correct library for this sensor.
Does anyone use this sensors and having the same issue?
