I have a question about an issue. I want to know why to this problem. I'm going to work on something related to remote control. First of all, I print the hex value of the command given from remote on the serial monitor with codes I found on internet. I use TSOP 2238 as reciever and 3 remotes as transmitter. One of the remotes is the Samsung TV remote. This remote works great with code. Each button on the remote has its own hex value. I can't get a fixed hex value in the other remotes I've shared the picture of blow.
@jremington Thank you for your answer. I think the carrierfreq is the same 38KHz. Because if the carrier freq isn't same , I won't see a value when I press the button. I don't know maybe I am wrong
I pressed the same button on the remote 3 times and each time I saw a different hash address on the serial monitor. Is there any way to fix this problem?
