this is a stripped down version of a much bigger program. the big program is an intrusion detector system for large properties
note: the code tags are behaving oddly. I am trying to correct that
one of the current aggravations is the RTC. It is detected, it starts, it does not object when I set it with the correct time, and it returns gibberish when I read it back after I set it.
I tried two T Beams and three RTCs and the result is always the same.
the code:
#include <WiFi.h>
#include <Wire.h>
#include <LoRa.h> // Sandeepmistry
#include <time.h> // ESP32Time
#include <TinyGPS++.h>
#include <HardwareSerial.h>
#include "RTClib.h"
RTC_DS3231 rtc;
#define I2C_SDA 21 // GRA 21
#define I2C_SCL 22 // VIO 22
HardwareSerial GPSSerial(2);
#define GPS_RX_PIN 34
#define GPS_TX_PIN 12
TinyGPSPlus gps;
String hostname = "T Beam Gateway 09G1";
const char* ssid = "yourNetworkName"; // "yourNetworkName";
const char* password = "yourNetworkPassword"; // "yourNetworkPassword";
const char* ntpServer = "us.pool.ntp.org";
//char date[10] = "hh:mm:ss";
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 3600;
struct tm timeinfo;
byte second;
byte minute;
byte hour;
byte day;
byte month;
byte weekday;
int year;
int counter = 0; // retry connections
void initWiFi()
WiFi.mode(WIFI_STA);
WiFi.setHostname(hostname.c_str());// define hostname
Serial.print("WiFi Scan start ");
// WiFi.scanNetworks will return the number of networks found.
int n = WiFi.scanNetworks();
Serial.print("WiFi Scan done ");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
Serial.println("#! | SSID | RSSI | CH | Encryption");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.printf("%2d", i + 1);
Serial.print(" | ");
Serial.printf("%-32.32s", WiFi.SSID(i).c_str());
Serial.printf("%4d", WiFi.RSSI(i));
Serial.printf("%2d", WiFi.channel(i));
switch (WiFi.encryptionType(i))
case WIFI_AUTH_OPEN:
Serial.print("open");
case WIFI_AUTH_WEP:
Serial.print("WEP");
case WIFI_AUTH_WPA_PSK:
Serial.print("WPA");
case WIFI_AUTH_WPA2_PSK:
Serial.print("WPA2");
case WIFI_AUTH_WPA_WPA2_PSK:
Serial.print("WPA+WPA2");
case WIFI_AUTH_WPA2_ENTERPRISE:
Serial.print("WPA2-EAP");
default:
Serial.print("unknown");
delay(10);
Serial.println("");
WiFi.scanDelete(); // Delete the scan result to free memory for other code.
Serial.print("Connecting to "); Serial.print(ssid); Serial.println(":");
WiFi.begin(ssid, password);
while (!WiFi.begin(ssid, password))
counter++;
Serial.print("WiFiv "); Serial.print(counter); Serial.print(" ");
delay(100);
WiFi.reconnect();
if (counter == 10)
counter = 0;
Serial.print("WiFi AP "); Serial.print(ssid); Serial.print(" not available ");
return;
void WiFiStationGotIP(WiFiEvent_t event, WiFiEventInfo_t info)
Serial.print("WiFi Station Got IP: ");
Serial.println(IPAddress(info.got_ip.ip_info.ip.addr));
void initTime(String timezone) // stable
if (WiFi.begin(ssid, password))
Serial.println("Getting NTP time: ");
while (!getLocalTime(&timeinfo) && counter < 10)
configTime(0, 0, ntpServer); // connect to NTP server, with 0 TZ offset
counter++;
Serial.print("NTPv "); Serial.print(counter); Serial.print(" ");
if (getLocalTime(&timeinfo))
Serial.print("NTP Time: ");
printLocalTime();
setTimezone(timezone);
Serial.print("Local Time: ");
printLocalTime();
setRTC();
Serial.println("NTPv: readParseGPS"); Serial.println();
readParseGPS();
void setTimezone(String timezone) // stable
Serial.printf("Setting Timezone to %s\n", timezone.c_str());
setenv("TZ", timezone.c_str(), 1); // adjust the TZ. Clock settings are adjusted to show the new local time
tzset();
Serial.println("timezone set. Set RTC to NTP time ");
void setRTC()
Serial.print("set RTC to: "); printLocalTime(); Serial.println();
rtc.adjust(DateTime(getLocalTime(&timeinfo)));
DateTime now = rtc.now();
Serial.print("RTC time set to: ");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println(); Serial.println();
void printLocalTime() // stable
if (!getLocalTime(&timeinfo))
Serial.println("Failed to obtain NTP time");
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S zone %Z %z "); // Friday, April 15 2022 19:18:51 zone MDT -0600
void readParseGPS()
if (GPSSerial.available())
while (GPSSerial.available() > 0)
gps.encode(GPSSerial.read());
if (gps.date.isUpdated())
Serial.print(F("GPS Year="));
Serial.print(gps.date.year()); Serial.print(" ");
Serial.print(F("GPS Month="));
Serial.print(gps.date.month()); Serial.print(" ");
Serial.print(F("GPS Day="));
Serial.println(gps.date.day());
if (gps.time.isUpdated())
Serial.print(F("Hour="));
Serial.print(gps.time.hour()); Serial.print(" ");
Serial.print(F("Minute="));
Serial.print(gps.time.minute()); Serial.print(" ");
Serial.print(F("Second="));
Serial.println(gps.time.second());
second = gps.time.second();
minute = gps.time.minute();
hour = gps.time.hour();
day = gps.date.day();
month = gps.date.month();
year = gps.date.year();
Serial.println("Set RTC to GPS");
setRTC();
Serial.println ("T Beam Gateway V009G1"); // current status
GPSSerial.begin(9600, SERIAL_8N1, GPS_RX_PIN, GPS_TX_PIN);
pinMode(GPS_TX_PIN, OUTPUT); // TO GPS RX
pinMode(GPS_RX_PIN, INPUT); // FROM GPS TX
Wire.begin(I2C_SCL, I2C_SDA);
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
for (byte i = 8; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
if (!rtc.begin())
Serial.println("RTCv");
else if (rtc.begin())
Serial.println("rtc.begin");
rtc.disable32K(); // disable the 32K Pin
rtc.clearAlarm(1); // reset alarm 1, 2 flag on reboot & recompile
rtc.clearAlarm(2);
rtc.disableAlarm(2); // turn off alarm 2 at reboot
rtc.writeSqwPinMode(DS3231_OFF); // stop signals at SQW Pin
rtc.setAlarm1(DateTime(0, 0, 0, 0, 1, 0), DS3231_A1_Hour);
Serial.println("Alarm(1) set to trigger every ten minutes for testing");
initWiFi();
WiFi.onEvent(WiFiStationGotIP, SYSTEM_EVENT_STA_GOT_IP);
initTime("MST7MDT,M3.2.0,M11.1.0"); // MST Timezone - Leo's Notes
setRTC;
the result:
16:29:14.810 -> T Beam Gateway V009G1
16:29:14.810 -> I2C scanner. Scanning ...
16:29:14.810 -> Found address: 87 (0x57)
16:29:14.810 -> Found address: 104 (0x68)
16:29:14.810 -> Done.
16:29:14.810 -> Found 2 device(s).
16:29:14.810 ->
16:29:14.810 -> rtc.begin
16:29:14.810 ->
16:29:14.810 -> Alarm(1) set to trigger every ten minutes for testing
16:29:14.810 ->
16:29:14.934 -> WiFi Scan start WiFi Scan done 1 networks found
16:29:19.255 -> #! | SSID | RSSI | CH | Encryption
16:29:19.255 -> 1 | yourNetworkName | -53 | 1 | WPA2
16:29:19.255 ->
16:29:19.255 -> Connecting to yourNetworkName:
16:29:19.255 -> Getting NTP time:
16:29:23.701 -> WiFi Station Got IP: 192.168.52.174
16:29:23.701 ->
16:29:24.264 -> NTPv 1
16:29:24.895 ->
16:29:24.895 -> NTP Time: Sunday, May 07 2023 22:29:24 zone UTC +0000
16:29:24.895 ->
16:29:24.895 -> Setting Timezone to MST7MDT,M3.2.0,M11.1.0
16:29:24.895 -> timezone set. Set RTC to NTP time
16:29:24.895 -> Local Time: Sunday, May 07 2023 16:29:24 zone MDT -0600
16:29:24.895 ->
16:29:24.895 -> set RTC to: Sunday, May 07 2023 16:29:24 zone MDT -0600
16:29:24.895 ->
16:29:24.895 ->
16:29:24.895 -> RTC time set to: 2106/2/66:28:17
16:29:24.895 ->
two questions: how does this get in the middle, when the code above is delayed to prevent this?
and where does this come from?
16:29:24.895 ->
16:29:24.895 ->
16:29:24.895 ->
