TTGO T3_V1.6.1 Bluetooth Functionality
I have a TTGO LORA32 T3 V1.6.1 board that I'm trying to setup to 1) receive a signal from a separate board that's setup as a LORA transmitter and 2) transmit that signal back out via Bluetooth. For now, I'm working with just a "Hello World" message; I've gone through the documentation and added what I believe is the correct code to do this (below). The code compiles fine, uploads fine, and everything seems to operate with no errors. Problem is, any device that I then try to use to "see" and connect to the TTGO as a Bluetooth device just can't see it (have tried my iphone, laptop, bluetooth serial app on phone, etc.).
No issues with the LoRa side of the code, that all works fine. And I do see the "The device is now ready to pair for Bluetooth" message come through via the serial monitor. I feel like I'm missing something obvious...any help is appreciated!
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "BluetoothSerial.h"
//LORA pins
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run 'make menuconfig' to and enable it
#endif
BluetoothSerial SerialBT;
//Initialize Serial & Bluetooth
Serial.println("Serial port initialized.");
SerialBT.begin("ESP32test");
Serial.println("The device is now ready to pair for Bluetooth");
// Initialize LORA
SPI.begin(SCK, MISO, MOSI, SS);
LoRa.setPins(SS, RST, DIO0);
if (!LoRa.begin(915E6)) {
Serial.println("LoRa initialization failed.");
while (1);
else {
Serial.println("LoRa initialized.");
int packetSize = LoRa.parsePacket();
if (packetSize) {
while (LoRa.available()) {
String receivedMessage = LoRa.readString();
Serial.print("Received: ");
Serial.println(receivedMessage);
SerialBT.println(packetSize);
I moved your topic to an appropriate forum category @jagovern.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
can you run File>Examples>BluetoothSerial>SerialToserialBT and connect to a Bluetooth Serial app?
