Hi All,
First of all thanks for your time. I have received a T5_V2.3.1_2.13 and trying to flash using GxEPD library (current master) I am not able to see anything (flashing as ESP32 Dev Module)
Display:
https://es.aliexpress.com/item/32869729970.html
#include <GxGDEH0213B73/GxGDEH0213B73.h> // 2.13" b/w newer panel
and in case it helps:
Chip is ESP32-D0WDQ6-V3 (revision 3)
Error 1: Minimum Example:
Flashes correctly but getting the following output on restart:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Any idea?
@a10pepo , welcome to the forum! Please read How to get the best out of this forum , if you haven't done yet.
You might take a look at this post . And one of the preceding posts .
Awesome, I was exactly looking for the version, I will give it a try and let you know.
Regarding the donation or ttygo happy to send a coordinate email to help them decide to donate to you
I will get back with my progress... Thanks in advanced
I am adding this comment so in case anyone has the same issue here is my solution:
Go to:
GitHub - Xinyuan-LilyGO/T5-Ink-Screen-Series: TTGO T5 V2.2 ESP32 2.9“EPaper Plus
Follow steps
Select the following
#define LILYGO_T5_V213
#include <GxGDEM0213B74/GxGDEM0213B74.h> // 2.13" b/w form GoodDisplay 4-color
Install ESP32 Sketch Data upload:
Releases · me-no-dev/arduino-esp32fs-plugin · GitHub
FLash it!! Magic!!!
system
Closed
November 2, 2021, 12:41pm
5
