I have a device that accepts a TTL input through a D-sub. I simply want to turn on and off the device using the Arduino. How should I connect the Arduino to device ?
Based on the very limited information provided, the forum cannot even guess.
Are you able to provide more information on this 'Device' ?
srnet:
Based on the very limited information provided, the forum cannot even guess.Are you able to provide more information on this 'Device' ?
Yes, Here is the link of the device (it is an optical shutter):
joseph2847:
Well historically TTL = Transistor Transitor Logic which was mostly 5V. So maybe a 5V output fron an Arduino would control the device.
The device link you posted leads you to a Manual, which clearly shows the TTL pinout in the D15 connector.
Pin 13 is TTL signal.
Pin 10 is ground.
https://oceanoptics.com//wp-content/uploads/INLINE-TTL-S-Installation-and-Operation-Manual.pdf
