TTL Signal from using Arduino Rev 3 to MOSFET Driver
I have been trying to make a pulse generator using Arduino Uno Rev 3 to drive MOSFET driver, which then drive MOSFET, by using TTL signal from Arduino. (5V in as Vcc and about 4.8 V in as TTL signal)
I am currently using Arduino Uno Rev 3 to supply voltage to MOSFET driver, IXDN614PI, which is connected to a MOSFET.
R2 and R3 are shunt resistors to prevent any damages from reverse flow of voltage when MOSFET and MOSFET driver is switching on and off.
However, when I run the Arduino, it starts off fine showing good square TTL signals, however as time passes, the driver no longer generate enough voltage to drive the MOSFET or even shows some signs of damages on signal output to the MOSFET.
And when I even removed the MOSFET and try to see pulse generation from MOSFET driver by oscilloscope, then it has same problem.
MOSFET driver runs for up to 30 minutes then dies down.
It no longer shows pulse at all or shows some damaging pulse, not a square, but a deformed square.
I have attached the schematic of connection that I have made for driving MOSFET driver.
May I get some suggestions on how to generate constant TTL signal from MOSFET driver?
Perhaps a stronge pullup on the enable pin? Is the decoupling ceramic and within 5mm of the package?
Oh, and is it getting hot?
Another possibility is too low a gate voltage. For this mosfet the Gate threshold voltage ranges from 2.7 to 5.6 V.
The Gate Threshold Voltage (Vgs) is the voltage where the MosFet just starts to turn on. I don’t recall the temperature effect on Vgs but perhaps you simply don’t have enough gate voltage.
Well ok, if we are going to troubleshoot the circuit using an oscilloscope, how about showing us the scope
screen images (before/after) by posting photos taken with your cellphone ?
Haven’t seen any mention of chip temperature ? Have you not touched the driver chip when it starts to
degrade ?
Also, no mention of gate driver Power voltage (VDD . What voltage is the driver running off ?
Have you checked the driver input when the output degrades ?
What is the value of R3 ?
The image refers to SCT3080ALG11, which seems to be a Silicon carbide MOSFET, SCT3080AL, which
has very stringent gate voltage requirements(*) - you cannot drive this without a specialist gate
driver powered at 18V.
The circuit shown will only control a logic-level silicon MOSFET.
(*) required gate drive 18V, gate abs max 22V, abs min -4V - heavy protection against
dV/dt induced voltage spikes would be needed to avoid gate breakdown as the leeway is only 4V
Compare with standard logic level MOSFET gate, usually +/-20V limit on gate voltage
and 5V nominal, so +15/-20V leeway available. Non-logic level Si MOSFETs usually have
+/-30V limit…
MarkT is correct. I didn't read completely through the specification the first time.
Please note the caution on the specification sheet:
Please be advised not to use SiC-MOSFETs with Vgs below 13V as doing so may cause thermal runaway.
Haven't seen any mention of chip temperature ? Have you not touched the driver chip when it starts to degrade ?
@OP, This is a good example of the importance of reading a datasheet thoroughly. (something most people hate to do but skimming datasheets is counter productive).(Really, who curls up with a long datasheet for bedtime reading ? (besides Paul_B)
SCT3080AL DATASHEET
MarkT:
Sorry, I am pretty new to this area, but what does it mean by decoupling ceramic?
And when I touched the MOSFET driver, it was not hot or getting warm.
raschemmel:
1.jpg is when the circuit starts, it shows some degradation already, but I think it is because I am currently using a damaged driver chip. I am waiting on new ones to come.
2.jpg is after about 30 minutes then 3.jpg happens.
And then it shows no signal.
And for driver input from Arduino Uno Rev 3, it was still abou 4.8 to 4.9 V.
And R3’s value is 1.05K Ohms.
For Vdd, SCT3080AL shows 300V (?) from datasheet, but MOSFET driver, IXDN614PI, does not have Vdd value on its datasheet.
MarkT:
+/-30V limit…
Ah, I see. Thank you for pointing that out. I am not too familiar with datasheet neither… I am very new to this area.
But I still do not understand why the MOSFET driver itself does not output constant ~5V values but degrades overtime.
Why are you asking this ?:
in view of this:
I still do not see an answer to this question:
What is the supply voltage for the driver ?
YMute: Sorry, I am pretty new to this area, but what does it mean by decoupling ceramic?
Is the decoupling capacitor for the driver a ceramic capacitor (it very much needs to be, and very close to the pins of the driver).
Which is encouraging.
The screen shots could indicate a poor connection somewhere. Was that the output of the driver when loaded or not loaded?
Did you look at the supply to the driver, checking it was a good solid 5V (that driver is rated from 4.5V up).
I repeat that SiC MOSFET, if its the one you use, requires careful attention to gate driver circuitry - remember all MOSFET gates are extremely fragile and will not tolerate over voltage for even a nanosecond, There's only a few dozen atoms between gate and source. It needs 18V drive without question, and it needs careful design to limit over- or under-voltage spikes on the gate in the face of source voltage bounce due to the self-inductance of the source lead. A standard Si MOSFET driver is not the device for non-Si MOSFETs, SiC nor GaN...
Just so we are all on the same page , the following comment:
is a reference to the MOSFET , NOT the mosfet driver, so feeling the driver is not going to tell you if
the mosfet is getting hot. Please indicate the Post # of the post where you indicate that you checked
the mosfet for overheating.
The mosfet driver is probably not working for the reasons already stated (VDD < 18v).
MarkT: Is the decoupling capacitor for the driver a ceramic capacitor (it very much needs to be, and very close to the pins of the driver).Which is encouraging.
For the 10 uF capacitor, I am using radial aluminum electrolytic capacitor, not a ceramic capacitor. And it is near the driver.
It was loaded with Arduino's 5V TTL signal with 0.1 Hz. But the output of the driver was not connected to the SiC MOSFET.
Yes, it was almost constant 4.8~4.9V from Arduino to the driver.
Sounds like I need to find a new MOSFET and change the SiC MOSFET out. Do you have any suggestion? We are looking to generate pulse as high as 1 MHz.
raschemmel: Why are you asking this ?: "But I still do not understand why the MOSFET driver itself does not output constant ~5V values but degrades overtime."
Even when I removed the SiC MOSFET to see if MOSFET driver would be damaged, the circuit somehow still damages or shows degraded values over time on oscilloscope. And I could not find it or seem to understand the problem correctly.
I still do not see an answer to this question: "What is the supply voltage for the driver?"
For supply voltage to the driver, it is 5V from digital power output port on Arduino Uno Rev3. It is almost like 4.9V when I probed with a multimeter.
Let’s review:
This comment:
Is a reference (obviously) to a decoupling capacitor (typically 0.1uF , ceramic, but could be mylar),
NOT a reference to a FILTER capacitor (typically 10uF to 100uF)
The following comment:
Should be:
I don’t have a decoupling capacitor. All I have is a filter capacitor. I will get a 0.1uf/ceramic or mylar decoupling capacitor and install it as close to the mosfet driver as possible.
Capactive Reactance XC = 1/(2Pif*C)
Case 1:
f = 0.1 Hz (100mHz from scope screenshot)
SCOPE SCREENSHOT:
Pi = 3.14159265359
C = 10E-6 uF (10uF from OP’s circuit)
Let C = 10uF (10E-6) F
XC= 159.1 kohms (CURRENT CASE AS GIVEN FROM SCHEMATIC
AND SCOPE SCREENSHOT)
Case 2:
Pi = 3.14159265359
Let C = 0.1E-6 uF (0.1uF (standard decoupling cap value)
XC= 15.1 Mohms
Case 2:
f = 1 Mhz (1 Mhz frequency proposed by OP in post)
Pi = 3.14159265359
XC= 1.59 ohms (CASE FOR 0.1uF Cap at 1 Mhz switching frequency)
CONCLUSION:
If you stop using 0.1 Hz and start using a higher , more realistic frequency (like 100 kHz)
AND add a 0.1 uF DECOUPLING CAP (in addition to current 10uF FILTER CAP), the decoupling
cap will pass high frequency spikes to ground , reducing noise.
