TTL singal for trigger in
Hi
i want to use arduino uno for sending the TTL signal to microscope Trigger unit.
i wrote a labview code using Linx.
i have seen there are two pins - Rx and Tx.
please suggest me which pin should i use as TTL output.
thanks
uva
Why get the Arduino involved? That is silly. Needlessly complex.
Buy a serial-to-TTL converter for your PC and control the microscope directly with LabVIEW.
Why use TX or RX; any pin on the Arduino can output a TTL signal. So I guess you first need to give a description of what really needs to happen.
Does the trigger circuit require serial communication?
If so, bidirectional or just a command to the unit (and no reply).
Etc
Etc
thanks for your reply. it works now.
