TTL
Transistor Transistor Logic
I am planning in building a little laser project with an arduino, the module i'm getting is:
http://www.dealextreme.com/details.dx/sku.10004~r.89439563
It is 5v and supports TTL on two wires and the other two wires are for ground and power it seems.
would i be able to control the module with the pwm pins on the arduino?
Just saying 5V does not mean it's TTL. From the page: "Cons: The 5v input is AC not DC. This is only a con because it isn't obvious unless you look at the board closely and some may accidentally try 5v DC."
say if i powered the laser module from:
http://www.maplin.co.uk/Module.aspx?ModuleNo=226&doy=3m4&C=SO&U=strat15
can i use the arudino to send data to the other two wires of the laser module?
No this power supply will still give out DC you want AC.
Form the posts it look like you can blank it with the output of an Arduino.
