Turn around time for flashing
In order to decrease turn around times for flashing the controller I have switched from the boot loader to avrisp quite some while ago. My current time for flashing a 644 (aka Sanguino) is roughly 12 seconds
avrdude: writing flash (37470 bytes):
Writing | ################################################## | 100% 11.73s
avrdude: 37470 bytes of flash written
Is there any board out there that can flash faster? Maybe the teensy? I am just very impatient :wink:
Another question along the same line: has anyone an idea why avrdude takes more than ten times longer to read the flash than to write it? That is if I dump the flash with avrdude it takes very much longer than reading it inside a loop a pushing it through the serial interface. Any comments on this?
In all cases I use a 644 @ 16 MHz
Maybe the teensy?
On my computer, it takes about 3 seconds to upload a 7484 byte Sketch to a Teensy 1. Most of the time seems to be from the USB removal / insertion that occurs when the Teensy reboots. If you provide a sample Sketch, I'm willing to perform a crude time test for you.
I can't help with the other questions.
I was more impatient than you, so I decided to find the fastest way to upload on to my Arduino Diecimila (with upgraded ATMega328 chip).
I used a modified Arduino bootloader (Loading...) and adjusted the serial baud rate to 1 Mbaud. Of course, avrdude (atleast on Windows) doesn't support non-standard baudrates, so I had to make my own uploader program.
The end result (uploading a 11794 byte sketch):
Writing | ######################################################## | 100% 1.32s
Reading | ######################################################## | 100% 0.38s
@coding badly: here comes a small upload benchmark
#define d(s) s s
void setup()   {
    char s[] = d(d(d(d(d(d(d(d(d(d(d(d(d(d("s"))))))))))))));
    char t[] = d(d(d(d(d(d(d(d(d(d(d(d(d("t")))))))))))));
    char u[] = d(d(d(d(d(d(d(d(d(d(d(d("t"))))))))))));
    Serial.print(s);
    Serial.print(t);
    Serial.print(u);
void loop(){ }
how long does this take for the teensy?
@waffle: I definitely have to try this :slight_smile:
Nice. Still takes just less than 3 seconds.
I found this thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1223527587
fiddling around I set sck to 1 --> big improvement
then I set sck to 0 --> this was stupid, now I need to figure out how to fix my programmer ...
OK, so now I entered the draded OS needed to run AVR studio, upgraded the ISP and set the programmer frequency to 4 MHz. Now it uploads very satisfactory:
Writing | ################################################## | 100% 2.07s
@coding badly: I think I definitely have to give the teensy a try
Thanks for any help :slight_smile:
Now I played again with avrdude and set SCK to 1 again --> now it requires one second more for flashing.
Has anyone any clue for my why this takes one second longer?
