Turn LED on with Serial Monitor and off with button
Hello,
I got a problem with my code:
I want that after “xx1-2-3” is entered in the Serial Monitor, a LED lights up. That works!
But the second step is, that after I pressed a button, the LED should go out. In my programm code, the LED ist just going out, while the button is pressed. After I release is, it lights up again.
Can you help me with this issue?
I tried several times to define an status for the LED, but it didn’t helped.
Thanks in advance
char c;
String Zeile;
String Feld[10];
int FeldAnz;
int LED=11;
int Button=10;
 pinMode(LED,OUTPUT);
 pinMode(Button,INPUT);
 digitalWrite(LED,LOW);
String ZeileLesen(){
  Zeile="";
  while(Serial.available()){
    c=Serial.read();
    Zeile+=c;
    delay(2);
  return Zeile;
void PositionLesen(){
  FeldAnz=1;
  for(int i=0;i<10;i++){
    Feld[i]="";
  int Len=7;
  int Pos=2;
  while((Pos<Len)){
    c=Zeile[Pos];
    Feld[FeldAnz-1]+=c;
    Pos++;
    ZeileLesen();
    PositionLesen();
    for(int i=0;i<FeldAnz;i++){
      Serial.println(Feld[i]);
    if (Feld[i]=="1-2-3"){
    digitalWrite(LED,HIGH);
  while(digitalRead(Button)==HIGH){
       digitalWrite(LED,LOW); }
  else{digitalWrite(LED,LOW);
I think you need to use an IF statement instead of a WHILE statement on the logic for your button.
IF digitalRead == HIGH, then, turn off LED.
not while digitalRead == HIGH turn off LED.
(Because then with that logic, you are doing the following: while digitalRead == LOW turn ON LED)
here's a conventional way of checking for a button press that is non-blocking
// recognize button presses; tgl LED when pressed
byte butPin = A1;
byte ledPin = 10;
byte butLst;
void setup (void)
    digitalWrite (ledPin, HIGH);
    pinMode      (ledPin, OUTPUT);
    pinMode      (butPin, INPUT_PULLUP);
    butLst      = digitalRead (butPin);
void loop (void)
    byte but = digitalRead (butPin);
    if (butLst != but)  {
        butLst = but;
        if (LOW == but)     // button pressed
            digitalWrite (ledPin, ! digitalRead (ledPin));
    delay (10);         // debounce
