Turn off the TFT backlight Adafruit 1.3"
So I'm trying to build a thing where when I press a button it displays an image for 20 seconds. I want long battery life so after 20 seconds I want to turn off the screen to save battery life.
I have been able to accomplish the screen going on, hitting a button to display an image and switch when I hit a different button. What I have no idea is how to turn the screen off. I've been able to figure out from forums there is turning the TFT off and turning the backlight off. I think I want the backlight to go off as that is what saves the most battery life.
I have the screen pin Lite plugged into D6. I assume I have to set that to something?
if (buttonStateBlue == HIGH) {
  //Code to turn screen on
  reader.drawBMP("/redSquare.bmp", tft, 0, 0); //display an image on screen
  Serial.print("blue button on"); // serial log to confirm it worked
  Serial.print('\n');
  delay(20000); //wait 20 seconds
  //Code to turn screen off
If you haven't figured this out yet, you are correct:
gamefe:
You simply have to turn pin D6 off and on as you want. Something simple like this should do the trick:
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(D6, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(D6, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(D6, LOW);    // turn the LED off by making the voltage LOW
That code is nothing more than the arduino Blink example that turns off and on the built in LED, adapted to work on pin D6 instead.
For reference:
https://www.arduino.cc/reference/en/language/functions/digital-io/pinmode/
https://www.arduino.cc/reference/en/language/functions/digital-io/digitalwrite/
Optionally, you could also connect the display's lite pin to an analog pin and change the analog pin's value over time to fade in/out the brightness of the back light.
Hope this helps,
Randy
