Turn on a LED and asign an adding up variable
Hello everyone! I am a newbie in the forum and in Arduino world and I need some help in a script I already did that works ok but have a problem that I couldn’t figure it out how to fix it. I have 2 buttons: the first one create a random number that keeps adding value in a variable called SUM until reach 20 and stops (everything is working fine here); the second button turn On a LED and put a variable of -10 everytime the LED is On. The problem here is that I want to substract -10 to the SUM variable everytime the button is pushed however, I am having problems because if I push the 1st button the SUM variable keeps substracting -10 in a loop instead of just subtracting -10 only when the botton is pushed.
Hope you can help me with this also, is there a better way to simplify my code?
Thank you a lot fo the advise!
Cheers!
Hector
This is the code:
#define PIN_BOTON_A 2
int pulsos_a = 0;
boolean anterior_a;
int randNumber;
int sum;
// --------------------------------------------------------------------------- boton add up
int ledPin = 13; // choose the pin for the LED
int switchPin =3; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
int counter = 0;
int currentState = 0;
int previousState = 0;
int sumf=0;
  randomSeed(analogRead(0));
  pinMode(PIN_BOTON_A, INPUT_PULLUP);
  anterior_a = digitalRead(PIN_BOTON_A);
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(switchPin, INPUT); // declare pushbutton as input
boolean estado_a = digitalRead(PIN_BOTON_A);
randNumber = random(int(11));
//--------------------------------- LED-------------------
val = digitalRead(switchPin); // read input value
if (val == HIGH) { // check if the input is HIGH (button released)
digitalWrite(ledPin, HIGH); // turn LED on
currentState = 1;
else {
digitalWrite(ledPin, LOW); // turn LED off
currentState = 0;
if(currentState != previousState){
if(currentState == 1){
counter = counter + 1;
sumf=-10;
Serial.print(counter);
Serial.print("-------- suma= ");
Serial.println(sumf);
previousState = currentState;
delay(15);
  if (anterior_a != estado_a)
      if (estado_a == LOW)
//-------------------------------------------------------------botton pushed ------------------------------
 if (sum<20)
          if (randNumber == 1)
            Serial.print(randNumber);
            Serial.print(" ------------ ");
            sum = sum + 2 + sumf;
            Serial.print("------- 2 ----- suma= ");
            Serial.println(sum);
                if (randNumber == 5)
                  sum = sum + 5+ sumf;
                  Serial.print("------ 5 ------ suma= ");
                     if (randNumber == 10)
                     sum = sum + 7+ sumf;
                     Serial.print("------ 7 ------ suma= ");
                         Serial.println(randNumber);
//-------------------------------------------------------------botton pushed------------------------------
  anterior_a = estado_a;
  delay(15);
You need to detect when the button becomes pressed rather than when it is pressed
Look at the StateChangeDetection example in the IDE to see how to do it.
