Turn ON a led during a defined time
Hy guys,
Is it possible to turn ON a LED (or do any action) during a defined time (variable) without using "delay(variable)" ?
I have 3 captors who register each a certain value, and it have to control 3 LED. I want them to switch ON at the same time, and switch OFF depend of my 3 values.
Thanks a lot !
Yes. Look at the BlinkWithoutDelay example in the IDE.
The principle used is as follows
Record the start time of an activity
Check frequently (each time through loop() is good) whether the current time minus the start time is greater than the required interval
If yes then take the required action(s)
Else do other things such as reading sensors
See also the demo several things at a time.
...R
