Turn on LED indicator when arduino uno ON for 5 second
hi there,i try to give external LED indicator for Arduino board when i give voltage input 5v on arduino ,my external LED turn ON for 5 second and then turn off.i try use millis.but it likes i use delay().but my External LED still blinking. because i dont want blinking my LED.
unsigned long interval=1000; // the time we need to wait
unsigned long previousMillis=0; // millis() returns an unsigned long.
bool ledState = false; // state variable for the LED
 pinMode(13, OUTPUT);
 digitalWrite(13, ledState);
 unsigned long currentMillis = millis(); // grab current time
 // check if "interval" time has passed (1000 milliseconds)
 if ((unsigned long)(currentMillis - previousMillis) >= interval) {
   ledState = !ledState; // "toggles" the state
   digitalWrite(13, ledState); // sets the LED based on ledState
   // save the "current" time
   previousMillis = millis();
Instead of toggling the LED state using
simply set it to the state that you require it to be at, either HIGH or LOW
thanks uncle!!!....GOD bless YOU!!!!
what you mean Sr, could you explain more please
Which part don't you understand ?
(simply set it to the state that you require it to be at, either HIGH or LOW)
this one sr
I change this.
with this :
bool ledState = true;
and change this:
with this:
ledState = false;
and this is what i want...hheheeh
The current code changes the state of teh LED when the period ends, so the LED blinks
If instead of
the code did
ledState = HIGH; // set the state to HIGH
Then the LED would stay HIGH after the period ends
NOTE: this is not the best way to do what is required but is simple to change the code to do it
thanks alot
thanks Sr
A smarter way to do what @ridhoazhar313 says he/she wants to do
boolean timing = true;
  digitalWrite(13, LOW); //start with LED off
  if (timing && millis() >= 5000) //test whether 5 seconds has elapsed
    digitalWrite(13, HIGH); //turn LED on
    timing = false; //no need to check again
great!!!.....thanks uncle!!
I try your smartest code uncle,but my LED keeps ON and doesnt turn off. :slightly_smiling_face:
The built in LED should start off and remain off for 5 seconds then turn on and stay on
Is that what it is doing ?
Your topic title says
In post #1 you say
One is the opposite of the other
Which do you want ?
Change the values in the digitalWrite() code lines to change what the code does
The sketch by @UKHeliBob from reply #11 in Wokwi with the led on for 5 seconds, then off:
ya,,,im sory..youre right..hahaha...thanks !!! :sweat_smile: :sweat_smile: :sweat_smile:
So which was it you wanted ?
its good,i have new knowladge to make simple code,and of course i need all...actually.Alhamdullillah!!!
